| F/S intake, exhaust, tinted tails |
| Wohoo Black Tail lights |
| tinted tails and took off vinlys |
| General Question About Tail Lights |
| headlight and tail light advice needed |
Blckdouttc
Reg'd: Jul 22, 2008 Master Mechanic |
I just re did my tail lights yesterday and they came out pretty good. Just thought i'd put together a little DIY. I know FLEA has one, this is basically the same exact thing but just right on the stockies and skipping the taping up parts he did on the TYC's Before: ![]() ![]() Clean them and scuff them up a bit with 1000 grit sand paper until the shine is removed, this helps the paint stick better to the plastic and help prevent runs ![]() ![]() Shake up the VHT for a minute or 2, then do a very light broad coat about a foot from the light, just letting the paint stick to the surface. i call it a mist coat. Since the 1st coat is always the hardest, this helps the paint stick to the plastic for a good base coat. I do 2 of these to be safe. 1st mist coat: ![]() 2nd mist coat: ![]() Wait about 4 or 5 minutes in between coats. keep adding coats about 5 to 6 inches from the light. If you run into drips or anything, wet sand that part lightly until it is removed. This is after about 6 coats or so of tint just keep adding coats until you reach the desired darkness: ![]() ![]() Now wet sand with 1000 grit sandpaper again until it appears as a smooth and grey looking. You want to be sure everything is smooth so it appears smooth in the end with no orange peel and stuff. Now while i was wet sanding, i went over that one crease by the reverse light that goes vertical up to the top too much and the red showed through. I just taped it off and re tinted that part, wet sanded it again untilit matched the rest of the light: ![]() Whole light wet sanded: ![]() Now its time to clear. I recently started using UPOL #1 clear which i love and works a lot better and is able to be handled in about 2-3 hours. Like the first coats of tint, do 1 mist coat to set the base and help it stick. Then the clear can be applied in heavier coats than the tint. I o about 4 or 5 heavy coats to get that thick, glossy finish. 1st heavy coat: ![]() After all clear. You can tell there is orange peel which is completely normal. We will get rid of it during the wet sanding: ![]() ![]() ![]() You should be able to see reflections clearly: ![]() ![]() I used to use the Duplicolor clear coat which I would let dry overnight, but this stuff only takes 2 or 3 hours. After 2 - 3 hours, lightly wet sand with 1000 grit at first, then when its almost completely smooth,move to 1500 grit to make everything smoothed out. After sanding: ![]() ![]() Now time to buff em out. It is best to use a buffer, if you try by hand, i dont wanna know how long it will take. Its basically 4 coats of 3 things. Rubbing Compound (I use 3M), then Meguiears Scratch-X, then a Wax ( I use Meguiars Hi Tech Yellow Wax). After 3M Rubbing Compound, this brings the black and some shine back: ![]() After Plastic-X: ![]() ![]() After Hi Tech Yellow Wax: ![]() ![]() Finished product: ![]() ![]() ![]() Hope this helps out! ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
vastano1
Reg'd: Sep 06, 2006 Godlike Advisor |
wow very detailed...good write up definitely click the link, donate some money to help improve our site/community CLICK ME TO DONATE AND HELP SQMK MAKE OUR SITE BETTER |
Reg'd: Aug 16, 2007
Stickied ![]() CLICK HERE TO DONATE & HELP MAKE THIS WONDERFUL SITE OF OURS BETTER! |
OldJersey
Reg'd: Jan 09, 2007 Vehicle Designer |
those are so shiny |
tinyscion
Reg'd: May 24, 2007 Detailer |
That looks sick and shiny. 07 Black Sand Pearl, the prettiest thing in the trailer park. ![]() ![]() |
VIP_tC08
Great write up looks sick as hell ![]() '08 // Flint Mica // tC |
sp007
Reg'd: Jun 18, 2008 Detailer |
It looks sick!! I think I will try doing mine as well!! |
Blckdouttc
i do do them for customers so if u want them done let me know ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
Blckdouttc
just a quick shot with the lights on, i didnt have anyone with me to press the brake lol ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
raz3091
Reg'd: May 31, 2008 Detailer |
Nice lol. Ever get pulled over yet? ;P |
audrey08
Reg'd: Nov 28, 2007 Tire Changer |
Thatz look nice dude. |
Blckdouttc
nope not once. i got asked about my tints before but not the lights lol ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
Blckdouttc
daytime shots with lights and brakes nothing on: ![]() headlights on: ![]() brakes and reverse light on, my TBL isn't plugged in lol, i also have LED's for reverse ![]() hazards/blinkers: ![]() ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
Wow, that's so much brighter then mine, lol! Looks great! ............... ![]() ![]() ![]() Donate or one of these adorable kittens WILL DIE! |
TCizzle06
Reg'd: Aug 19, 2005 Detailer |
Looks good... |
Blckdouttc
thanks guyss ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
tCracer2006
Reg'd: Oct 27, 2006 Vehicle Designer |
That is so tru they are. Plus you dont have to squint when he breaks to see him either i bet. hahaha dude it looks mad sick. It looks dark as shit but the lights are bright as hell even with out the brake being hit. Great work. 5 Stars!! |
Blckdouttc
triple post ftw? lol ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
reggeton87
Reg'd: Oct 22, 2007 Scion Guru |
dam kid this looks great. i wanna tint mine but only the top part and then leave it red on the bottom. Life is hard!! deal with it how ever you can! you do what you can and thats the bottom line. |
ladiablette
Reg'd: Jul 13, 2008 Oil Changer |
wow i love how the lights are bright even in daylight.. i just saw a car today with tinted tails that barely showed any lighting when he braked.. so i see you do it for ppl.. i just ordered some tails from ebay.. how much do you charge do do them? |
Blckdouttc
$75 and i do them and ship them back in about 7 hours ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
twiztidtC
Reg'd: Apr 12, 2008 Detailer |
Thanks for the link in a previous post. I did them this weekend using this DYI. I went on the lighter side for now, just to see how it goes (I had tinted tails on my 06' and ran into some issues because they were too dark). Thanks for the awesome DYI! ![]() Livin' Loud & Addicted to Bass http://cardomain.com/ride/3086512 |
Blckdouttc
no problem, glad it helped, they look good in that pic! ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
Aciidsneaker
Reg'd: Feb 24, 2007
Look's nice does your center tail light not work? ![]() ![]() Scion Wiki ~~ |
Blckdouttc
it was disconnected in those pictures ![]() 2006 BSP tC WANT YOUR TAIL LIGHTS TINTED? PM ME LIMITED TINT/CLEAR LEFT |
