| 2 Girls 1 Cup (Clean Tread, No worries) |
| anybody with P1 JDM SIDESKIRT |
| WTB: T-mobile cell phone |
| RS-1 Front Lip Installation? |
| Luminics pure blue H1 |
edboy21
Reg'd: Apr 28, 2008 Window Washer |
i need to start doing my oil change and im hoping to find out which one do you guys prefer between the two? |
O5_TRD_tC
Reg'd: May 16, 2008 Vehicle Designer |
I use mobil 1 w/ OEM Toyota filters The 4 LED_Headz: Ed (etli), Trung (SquallLHeart), Alan (O5_TRD_tC), and Paul (Dakine) |
^^ Same here. Good combo IMO ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
BRsciontc
Reg'd: Aug 17, 2007 Master Mechanic |
I use mobile 1 also. ![]() ![]() |
dsm3383
Reg'd: Mar 14, 2007 Scion Guru |
Ugh to both! Mobil 1 used to be one of the top oils on the market until Mobil and Exxon combined to ExxonMobil. Now they suck. C'mon Ferrari used to only use Mobil 1 and recommended it to only be used in their cars but now it's Quaker State. That should let you know that if Ferrari prefers QUAKER STATE over Mobil 1 now then there is a good reason ahaha! Royal Purple usually contains graphite in all their products. This is beneficial for lubrication and everything for that specific time but after use the graphite will increase wear on the internal components. I used Royal Purple in my trans for a bit but after time my trans did not feel right. Swapped to Lucas Oil and it made a huge different. IMO I prefer Valvoline. I only use SynPower and love it. Never a problem and been using it in three cars that I have owned. Beer is proof that God loves us and wants us to be happy. -Ben Franklin |
Thats what I use. Its affordable, easy to find, good quality. And I doubt I'd be able to tell the difference between most motor oils, haha. ![]() "I have an idea! An idea so smart, my head would explode if I even began to know what I was talking about." - Peter Griffin -- Want to post a "For Sale" thread? Check out the rules first. |
air2thethrown
Reg'd: Mar 19, 2006 Detailer |
I put Royal Purple oil w/ WIX filter. But next oil change I will out Mobil 1 oil w/ WIX filter. |
Mobil 1 with OEM filter. Royal purple is not a good choice due to the graphite DSM mentioned. Great lubricant but horrible when it builds up and hardens into almost concrete. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
RouletteTc
Reg'd: Jul 06, 2007 Scion Guru |
I have mobil 1 ![]() -Thanks for the sig Aciidsneaker |
07sctc
Reg'd: Feb 16, 2008 Tech Advisor |
mobil1 = exxon = 75% market share in gas = HIGH gas prices = im not gonna buy either exxon or mobil products....we all gotta quit feeding the beast. my .02 on that. i have heard that the royal purple is good though. edit - im running valvoline 5w-20 fully synthetic beware of the mad sciontist ! ask me your car audio and electronics questions!! a little signature love for good sellers.... FULL TBL KIT! HVAC/GAUGE LEDS garage1217.com HID's WHEELS discounttiredirect.com (speak to Justin) TINT (Car Show in Anderson, SC BEST Tinter Around) |
hahaha....Hooray for higher gas prices! ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
edboy21
i guess royal purple is out the window. is that true that some oil can actually improve mpg bcoz of better engine combustion? if there is, will mobile 1 do that for me? |
VIP_tC08
Mobil 1 w/ K&N Oil Filter here ![]() '08 // Flint Mica // tC |
That theory lies behind the oil's viscosity. The thicker the oil, the more the engine has to work to move the internals through it. Just think of how hard it would be to swim through cream cheese as compared to water. The thinner the oil, the faster the internal components can move, and as the theory goes, the better mpgs you get out of the engine. But, the downside to thin oil is that it burns off faster as well. Thicker oil is more resistant to thermal breakdown due to it's higher viscosity, but also robs the engine of it's possible power output. The best thing for our engines would be to run a moderately thin oil but not too thin. 5W-30 is usually the best grade to go with due to it's low cold start viscosity and decent operating temperature viscosity and thermal breakdown properties. Unless you're turbo or S/C or live in either Arizona or Maine, I'd stick with 5W-30 for our engines. Hotter climates can deal with thicker oils b/c initial viscosity (xW) is not as important as operating temperature viscosity (-x0). Colder climates want a thiner oil that has a lower cold start viscosity so that the oil can get pumped through the block faster to lube critical engine components. Hopefully this helps. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Racr350
Reg'd: May 18, 2007 Chief Mechanic |
x2 ![]() -BearZ Rules! |
edboy21
it helps alot...thanks web! |
no problem ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
CadenceScion
Reg'd: May 27, 2008 Oil Changer |
I use Mobil 1 5w30 w/ K&N Oil Filter. I change my oil every 4000-4500 miles. |
carcandy
Reg'd: Jun 14, 2007 Silver Sponsor |
I use ENEOS in all of my cars. I also have it in stock. |
killer08tc
Reg'd: Jun 14, 2008 Detailer |
Mobile 1 for the win no problems and I beat my car daily ![]() 252 hp and 243 ft lbs (only 5 psi spring moves up to 6 psi) 14.3 @ 103 mph |
CadenceScion
Also not to mention w/ thicker oils, it takes longer for the oil to get from the oil pan, to the oil pump, to the engine, due to being much thicker. Thicker oil will kill engine performance and also gas mileage. Pending on where you live, thicker oils are not always bad. Hot climates, you'll want a thicker oil. Cooler and really cold climates you do not need thick oil. Most cars/trucks run better on 5w30, compared to pre 1989 when most cars/trucks were 10w30. Oil has come a long ways from yrs ago when our parents were our ages. Oil lasts much longer and holds up better. Plus more abuse can be taken w/ todays oils, than from before. In my opinion all oil is not the same and neither is gas that we burn in our engines. It all comes down to the ingredients/additives. |
keys101
Is mobil 1 full synthetic?? Hows quaker, any good?? |
rimjay
Reg'd: Jun 01, 2006 Godlike Advisor |
mobil 1 does have fully synthetic oil, they also have synthetic blends, etc. get the fully synthetic. i use mobil 1 w/ k&n oil filter, yea, k&n, dont ask why i just like k&n...wanna fight about it? |
fponce
Reg'd: Nov 02, 2007 Chief Mechanic |
mobil 1 fully synthetic w/ oem filter... |
nola_tc_papi
Reg'd: Jun 08, 2008 Window Washer |
interesting to see this because im going to have to start doing my own oil changes too. i was going to go with royal purple but had no idea about the graphite component. thanks for the heads up. "Nothing shocks me, Im a scientist" |
