Home > Visual / Audio Mods > Wheels & Tires > problem wit rims
problem wit rims
keys101
Reg'd: Jul 26, 2007
Chief Mechanic
well i just got my lowering springs put on... then i got my new rims and tires mounted balanced and put on... I love them soo far but from 75 to like 90 mph the steering wheel shakes and on hard braking it really shakes.. They said my rims were a tiny bit worped and had some up and down play to them, but im hoping to god thats not why.. I havnt gotten an alignment yet but am goin to, what could be the cause of this???
[#] Jul 19, 2008 12:38pm
killer08tc
Reg'd: Jun 14, 2008
Detailer
well if they had the tire on the balancer and it said that it may be true
but if they just said that without testing then it could be you lost a wheel weight
252 hp and 243 ft lbs (only 5 psi spring moves up to 6 psi)
14.3 @ 103 mph
[#] Jul 19, 2008 01:06pm
MrScion07
Reg'd: Sep 09, 2006
yeah sometimes those stick on wheel weights fly off that could b it. Take them back and have them look over em. If there was a little warp i still wouldnt ride with a rim like that
[#] Jul 19, 2008 01:11pm
07sctc
Reg'd: Feb 16, 2008
Tech Advisor
do you have hub-centric rings for the new rims? i had this problem on my last vehicle. The hub rings will center the wheel on the hub instead of trying to get the wheel perfectly centered by the lug nuts. the center bore in the aftermarket rims is hardly ever the same size as the hub on the car. Stock rims dont need them because the rim is designed to fit the hub snugly. The rings are cheap and you can order them from most any wheel shop. I got mine at discounttiredirect.com with my rims. i hope this helps.
beware of the mad sciontist !
a little signature love for good sellers....
FULL TBL KIT! O5_TRD_tC
HVAC/GAUGE LEDS garage1217.com
HID's operatic
WHEELS discounttiredirect.com (speak to Justin)
TINT (Car Show in Anderson, SC BEST Tinter Around)
[#] Jul 19, 2008 04:44pm
TOP: Home > Visual / Audio Mods > Wheels & Tires > problem wit rims
