Home > Performance Mods > Suspension & Brakes > Question bout vibration of steering wheel when braking
triniosito
Reg'd: Nov 15, 2006
So heres the situation if im going 50 and i gotta slow down pretty fast my steering wheel starts to shake left to right....kinda like vibrating....so im thinking it might be my new tires i just had installed a few weeks ago probably need to be rebalanced or it might be an alignment issue....any and all sugestions are welcome...thanks
[#] Jul 18, 2008 12:42am
Spitfire
Reg'd: Jul 02, 2008
Master Mechanic
an allignment problem could also cause this. happened to my jeep slowin down to 55mph, i would vibrate right off the road...
-wayne
08' BRM tC
A monkey in a suit is still just a monkey...
[#] Jul 18, 2008 12:45am
O5_TRD_tC
Reg'd: May 16, 2008
Vehicle Designer
most likely your tires were not balanced correctly.
The 4 LED_Headz:
[#] Jul 18, 2008 12:52am
Reg'd: Apr 17, 2006
THE SHADOW
Alignment would cause vibration, more of a constant pull. Balance issues would cause vibrations but if it's been a few weeks, then it's odd that it would just start now (depending on how much you've driven too). Check your brakes as well b/c if it's ONLY when you brake, your rotors may be warped.
[#] Jul 18, 2008 08:41am
brianc500
Reg'd: May 19, 2007
Master Mechanic
If you only have the vibration when braking, than it's more likely to be warped roters like Web suggested. A balance issue will usually be more consistant and may go away at some speeds.
[#] Jul 18, 2008 08:46am
xcessivenoize
Reg'd: Apr 15, 2008
Master Mechanic
^x2 with web and brian vibration under braking is caused by warped rotors. to fix this you need new front rotors and pads.
[#] Jul 18, 2008 03:25pm
Reg'd: Sep 29, 2007
I'd say warped rotors too
220+ WHP - 14.044 @ 97.02 MPH
[#] Jul 18, 2008 03:44pm
Reg'd: Mar 05, 2006
I had this same problem when my wheels weren't balanced correctly. Is it a violent shake of wheel or just a little vibration?
[#] Jul 18, 2008 03:49pm
Reg'd: Sep 29, 2007
Did it only happen during braking though? Because only during braking = warped rotors.
[#] Jul 18, 2008 03:50pm
triniosito
Reg'd: Nov 15, 2006
its more a wheel shake than vibration
[#] Jul 19, 2008 04:15am
triniosito
Reg'd: Nov 15, 2006
yea only during semi hard braking
[#] Jul 19, 2008 04:16am
xcessivenoize
Reg'd: Apr 15, 2008
Master Mechanic
warped rotors bro thats your prob
[#] Jul 19, 2008 06:05am
VIP_tC08
Reg'd: Dec 02, 2007
Check the lower ball joints on the front-end. You will find that they could be loose and the cause of your vibration problem
'08 // Flint Mica // tC
[#] Jul 19, 2008 08:00am
TOP: Home > Performance Mods > Suspension & Brakes > Question bout vibration of steering wheel when braking
