| What should I do? |
| What to do what to do!! |
| Tires!! What do you think? |
| What do you guys think is better, a two tone paint job or realistic fire paint job? |
| what can i do if there is a scratch on the car? |
07TouringCoupe
Reg'd: Jul 14, 2007 Scion Guru |
Just like the title says What to do for a stricly Nitrous setup? A car is only as good as it's driver. |
Headlessmunky
Reg'd: Feb 04, 2008 Detailer |
fuel injectors, engine management,intkae exhaust, rods. pistons, sleeves, head work, rod bearings, maybe a crank(not sure what the stock can hold. ![]() Save P2P ^If you support P2P^ |
asdfghjklakamj
Reg'd: Dec 27, 2006 Window Washer |
im currently running a 75 shot fine through all gears. i just bought a NOS Launcher progressive controller to ramp up the nitrous through the gears and im upping it to a 100 maybe 125 shot. and colder plugs.. |
TCMEX
Reg'd: Oct 29, 2007 Window Washer |
you´re doing this with stock internals?? |
asdfghjklakamj
yep. ill have it all put on hopefully by next week. its a ZEX 100 wetshot, with a booster fuel pump, ZEX spark plugs and Launcher progressive controller to ramp the nitrous and retard the timing. all internals are stock and should be fine. but ill let you know what happens ha. |
07TouringCoupe
If i were you i wouldnt run Zex spark plugs. I had them in my tc and fouled them. I would stay far away from them A car is only as good as it's driver. |
asdfghjklakamj
thanks for the advice. luckily i hadnt ordered them yet. |
07TouringCoupe
Yea. So i would sasve the time and get iridum or copper plugs A car is only as good as it's driver. |
JRod_TC
Reg'd: Apr 18, 2008 Master Mechanic |
Save yourself some time/money and just put some C4 in engine then turn it on... |
asdfghjklakamj
good advice. ill let you know how it goes asshole. we arent here to criticize peoples decisions, but to share information. he asked what a good nitrous setup should be, i told him what i was planning on running and that id let him know how it went. if you want to be a douche go somewhere else. |
07TouringCoupe
Definatly. That comment was uncalled for.. See ppl dont realize that turbo/supercharger isnt any better than nitrous. They all are types of F.I. and they all can fuc* your car up if used wrong. Point blank period A car is only as good as it's driver. |
breakout831
Reg'd: Mar 11, 2008 Tech Advisor |
I love the pungent smell of nitrous in the morning |
