| Changing my Sub's and amp out. |
| AMP placement help |
| amp help guys |
| need help with new better system and amp choice |
| subwoofer and amp help |
ErnDawg
Reg'd: Apr 15, 2007 Vehicle Designer |
ok everyone. i recently had to change my battery. i was in a hurry and i disconnected my amp without turning it off(car was off of course) or disconnecting the fuse. this is the first time ive ever disconnected it. now i was about to re-connect it at home and the wire clashed with metal and there was a spark. i'm a little freaked as i dont want t get electrocuted or blow my amp. how do i go about re-connecting it? should i disconnect the whole battery? theres only one wire, i assume it was grounded someplace else by the installer. help...please... thanks in advance. |
vastano1
Reg'd: Sep 06, 2006 Godlike Advisor |
ive done that before...it sparked once for me, but nothin big...i just connected it again and no spark...everything was fine...that was just my experience tho...i guess it wouldnt hurt to disconnect the power wire from the amp... click the link, donate some money to help improve our site/community CLICK ME TO DONATE AND HELP SQMK MAKE OUR SITE BETTER |
mrwilson99
Reg'd: Jun 30, 2008 Window Washer |
You should be able to reconnect the amp, but if you have an inline fuse about a feet away from the battery terminal and you touched any metal part of the car...you might have blown your inline fuse. So, reconnect and see if your amps turns on. If it doesn't, then you know is your inline fuse. |
