| what color calipers =/ |
| 2 Tone Brake Calipers |
| Clean LED swap! |
| painted calipers |
| engine cleaning |
beyond305
Reg'd: Jun 03, 2008 Oil Changer |
Ive got mine painted red and they got kinda dirty the past few months... Ive done everything except remove the wheels to try and clean then. Ive used several degreasers and have let em sit for a little before rinsing and then repeated the process. Anyone got a good method that doesnt involve removing the wheels? I need to get a brush or something in there... |
CrashUSAF
Reg'd: Apr 17, 2008 Scion Guru |
Its not really that big of a deal to remove the wheels is it? Thats really what I would suggest. Take them suckers off and get a brush on those calipers is probably the best solution. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Pressure washer? Probably can't be good for your calipers though if you do that. Edited Thread Title to "Calipers" instead of "Caplipers" ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
Yeah, if you really want to get em clean, take the wheels off and wash them with a cloth/sponge and car wash soap. But if you are lazy like me, do the same thing only leave the wheels on and fit your hand through the spokes of the wheel. ![]() "I have an idea! An idea so smart, my head would explode if I even began to know what I was talking about." - Peter Griffin -- Want to post a "For Sale" thread? Check out the rules first. |
scionteecee
Reg'd: Dec 02, 2007 Chief Mechanic |
I was gonna say the aerosol caliper cleaner but since you painted yours then the best bet would probably be car wash soap. |
Soap and water.......pressure washer and chemical sprayers will trip the paint. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
beyond305
pressure washer wouldnt strip the paint if you painted em correctly. Ive held the pressure washer directly onto the capliper and sprayed it down. No paint chipping or peeling, I used engine enamel to paint em and before I painted em I degreased em and clean the heck out of them. I will try this brake cleaner stuff you mentioned. Soap and water will do nothing to them. I need something to eat thru the brake dust sorta like degreaser does to stuck on egine oil. |
killer08tc
Reg'd: Jun 14, 2008 Detailer |
just made my calipers white cant wait to clean them ![]() 252 hp and 243 ft lbs (only 5 psi spring moves up to 6 psi) 14.3 @ 103 mph |
Brake cleaner has a chemical base that will peal paint. It says on the bottles to wash off quickly if you spray it on paint. Pressure washers weaken the bond paint has to their surface so the more you do it, the faster that paint will start to fade/chip. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Reg'd: Aug 16, 2007
After a while of pressure washing, it will eventually start chipping the paint. If you want to thoroughly clean them, take off the wheels, and use a degreaser. |
