| custom cars lol |
| Custom Window Decal, Questions & Ideas? |
| Custom Paint in Socal |
| custom box is finally done |
| need help with an in dash |
DavidM21715
Reg'd: Jun 03, 2008 Window Washer |
So i've seen with alot peoples Tc that that have modified the trim around their air vents, and the area surrounding the cd player, HVAC etc and i wanted to know how easy it was to change it and what to use (i.e. spray paint, brush paint, or whatever it might be) and also the trim around the air vents do they pop off the same as the trim around the cd player thanx for letting giving insight |
Spray paint. Duplicolor auto paints work great. Just be patient - Good tape masking, light coats with plenty of dry time, wet sand with FINE sandpaper (2000 Grit), then clear coat. and yes, the vents do pop off. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
xlox89x
Reg'd: Jul 20, 2007 Vehicle Designer |
im doing this right now actually. its really easy to take all the pieces off. i sanded mine lightly with 400 grit sand paper first, then wiped everything down with alcohol to get finger oils off them, then i just used spray paint. i'm doing 3 coats. 1 coat a day and letting it dry good, then 2 coats of clear coat, 1 coat a day. |
Kurisutaira
i used TESTOR's model spray paint. the vents on either side are a lil more work then the waterfall and the gauge cluster. just make sure u sand b4 u paint "This is what happens when an unstoppable force meets an unmovable object" The world will look up and shout "Save us!"... And I'll whisper "No." |
Reg'd: Aug 16, 2007
why is this in intakes?? moved to interior styling |
CrashUSAF
Reg'd: Apr 17, 2008 Scion Guru |
Isnt 1 coat a day a little excessive on the drying time? I was hoping to have my full setup done in about 6 hours or so. I plan on doing mine tomorrow if I can get around to it. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
VIP_tC08
For mine = i used Duplicolor auto paint, Duplicolor adhesion promoter, Duplicolor auto clear, and 2000 Grit sandpaper...vents pop off, but i recommend popping them out by pushing from behind trying to remove them from the front can lead to breaking the vents fastening clip ![]() '08 // Flint Mica // tC |
bLaCkDaHLiaTC
Reg'd: Jul 10, 2008 Tire Changer |
i plan on doing mine also, hopefully next week.. need to find the right color though |
Reg'd: Aug 16, 2007
1 coat a day is too much. Wait 15 minutes in between each coat. |
