| brake pads and rotors |
| WTB brake oil cap |
| If you turbo you gotta upgrade the brakes, right???? |
| REVIEW: Agency Power stainless steel brake lines |
| hot rotors after pad replacement |
pooorboi
Alright perhaps I havent searched hard enough but I can't seem to find an answer. I hear some bad scraping from m brakes all of a sudden so thenext day (today) I take out my pads and check them out. I found the problem. One of the metal shims on my passenger side front brake was half fallen off and was rubbing against something. Also it's really close to about time to change my pads. ok two reasons to buy new pads, already on order. HERES WHERE MY QUESTION COMES IN... i went to the drivers side and took off the pads. THEY WERE LESS THAN HALF WORN... have any of you come across this same problem? |
That would be due to uneven caliper pressure distribution. One side of the car is braking harder than the other. Possible caliper piston stuck or not retracting completely on one side vs. the other. ![]() Complaining is futile when you supported the victory. |
O5_TRD_tC
theres only 1 metal shim per pad, it didn't fall off The 4 LED_Headz: Ed (etli), Trung (SquallLHeart), Alan (O5_TRD_tC), and Paul (Dakine) |
pooorboi
right... thats what i meant/wrote. that one metal shim was hanging off. |
pooorboi
do you know how to fix that??? **off topic- went with EBC greenstuff |
You have to check if you have any air in the lines or any rust build-up in the piston bore on the caliper. Only way to check either is to flush the brake system thoroughly and bleed it or remove the caliper after bleeding the system, remove the piston seal and inspect the piston in the housing of the caliper. If all is well, then reverse the steps and thoroughly bleed the system afterwards. ![]() Complaining is futile when you supported the victory. |
pooorboi
DOOD!!! Mucho Gracias! It's about time for me to bleed/replace my brake fluid anyways... (been 85,000 miles and still running on OE fluid) ........ |
That could be attributing to the problem. Bleed the system and replace the pads and see how they feel. B/c brake fluid loses it's ability to hold pressure upon itself over time due to moisture contamination and pressure breakdown, that could help out a lot. Good luck. ![]() Complaining is futile when you supported the victory. |
Yes definitely rebleed the brakes. Actually, you should fully re-bleed the full system, but make sure not to let the master cylinder get empty. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
and to just add to the discussion yes, it is natural for pads to wear unevenly... due to typical turning of the car and other normal driving conditions.. i believe someone told me the front left and rear right brake pads tend to go out before the others.. or something like that... LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
brianc500
Also, if your going to tear apart the front brakes, make sure you have an ample amount of caliper grease on the hardware where the pads sit. This way you know for sure that the pads are not hanging up causing the caliper not to retract properly. Also might not be a bad idea to remove the hardware and clean them thoroughly since you do have 80,000+ miles on them. ![]() "Losing is often a temporary condition, giving up makes it permanent." |
That's only if you need to open up the caliper - I don't think he'll need to. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
pooorboi
I'm hoping not to have to crack open the calipers. This weekend I'm hoping install the pads and definitely flush the whole system and replace with synthetic. I was trying to be sarcastic before... I know I'm LOOOOOOONG over due on the fluids. |
pooorboi
thats good to know but i'm gonna post up some pics and could you tell me if this much difference is normal. i was suprised when i saw it. this is my first brake job that i've done myself so i dont know what's within exceptable/expected limits. this is the driver's side front ![]() this is the passenger side front this is the drivers and this is all four front pads. ![]() and this is a papparazzo close up |
pooorboi
also when i bleed my brakes im not trying to get air out, i'm replacing the existihng fluid, so do i need to drain out the old fluid? or do i just bleed the brakes, fill the resvoir, bleed, fill, bleed fill? and if i do this than how do i know when to go on to the next caliper/how do i know when all the fluid in the caliper i am working on has been completely replaced? |
Wow that's a big difference in pad wear.... ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
Start with the passenger rear, then driver's rear, then passenger front and last driver's front. You can do a gravity bleed (just crack the valve and let the old stuff run out and continually fill the resevoir)...it's slow but still works. You can do a one man bleed if you want and that keeps the air out of the lines. But, I recommend draining all the fluid from each line and THEN one many bleeding. Don't let the resevoir run dry EVER!. ![]() Complaining is futile when you supported the victory. |
