Home > Visual / Audio Mods > Audio FAQ/Help > Headunit and Sideview Mirrors Don't Work.
Peezytc
Newport News
Ok so here goes.
I get into my car and press the power button on my headunit, it doesn't turn on. My first reaction is probably a fuse blew out. Then I goto adjust my mirrors, and they don't move. Again I think to myself blown fuse. So I goto the store, then come home. I pop the hood, take off the fuse cover and pull out each fuse one by one. None of them are blown. So I'm stuck. I have no idea whatelse it could be. Has anyone else had this problem, or maybe know why this is happening? Any info would help. Thanks.
[#] Jun 18, 2008 05:20pm
tCdreamer87
New York
take it back to the dealer let them figure it out. you should still be under warenty
Life is hard!!
just sit back let go and let god deal with it!!
[#] Jun 18, 2008 05:35pm
Perry Hall
  • $upervillain
there are also fuses inside the car in the panel on the drivers side to the left of the steering wheel. Not sure where the one you'd be looking for is though.
[#] Jun 18, 2008 05:38pm
Peezytc
Newport News
The only reason I'm iffy about going to the dealership is because I have a system hooked up. I don't know if they are goning to tell me its my fault because I was messing with the electrical stuff in the car. The thing is everything was working yesterday.
[#] Jun 18, 2008 05:51pm
tCdreamer87
New York
oh your rite they are going to try and blame it on you. my gues is just check all the fuses again
Life is hard!!
[#] Jun 18, 2008 06:02pm
xcessivenoize
San Bernardino
like frank said look at the fuses on the left side of the steering wheel, below mirror controls, behind cover, if im not mistaken thats where the radio and mirror control fuses are located. its possable whoever installed the radio tied into the closest ac hot wire they could find and it happened to be the mirrors.
[#] Jun 18, 2008 06:09pm
Peezytc
Newport News
Thanks for everyones replys. I'm going to check those fuses inside the car now and see how they look. I'll keep everyone posted.
[#] Jun 18, 2008 06:50pm
Peezytc
Newport News
So, I checked the fuse in the car and all of them are fine as well. None are blown, so now I really at a dead end. I guess tomorrow I'm going to heading up to the stealership and see what they say.
[#] Jun 19, 2008 12:20am
xcessivenoize
San Bernardino
i would take it back to the shop that installed the stereo first and see if they can find the prob. it deals with the stereo so they should honor there install and workmanship, plus the dealer might charge you a lot just to tell you they cant fix it cause its an aftermarket install. not to mention they will prob keep your car all day where as the stereo shop will only take about an hour or two to fix, if its there fault it doesnt work.
[#] Jun 19, 2008 02:24am
  • The Techie
look at the fuses again buddy
the one for the audio system specifically is #8 which is in the fuse box under the hood.
now another one is fuse #35 which is your likely culprit... it's a 7.5 A fuse (it's brown in color) that provides 'ACC' power to the radio.. and GUESS WHAT.... ALSO to the power mirrors.
(that one in the in-cabin fuse box)
oh yea... and pssst... the info i just told ya?
it's IN THE OWNER'S MANUAL.
Decelerate your life.
[#] Jun 19, 2008 07:06am
TOP: Home > Visual / Audio Mods > Audio FAQ/Help > Headunit and Sideview Mirrors Don't Work.
