Home > Performance Mods > Transmission / Drivetrain > gear oil change
gear oil change
Reg'd: Jan 03, 2007
its time to change my gear oil, ive been using redline mt90 for the past 28k'ish miles, thinking about using the same stuff unless sum1 has any other oils that they recommend? i know someone was using Amsoil stuff (i think Web), how would u rate it and what exactly did u get from Amsoil?
[#] Jun 18, 2008 02:47pm
Reg'd: Oct 21, 2005
$upervillain
http://clubsciontc.com/fo...l-transmission-only-.html
Has pics of the Amsoil. I'm running the same thing and love it. Smooth shifts everytime.
Even Zombies can Search...
[#] Jun 18, 2008 02:50pm
Reg'd: Jan 03, 2007
i guess i have to estimate 2.5 quarts lol, ill add 2 quarts and then half of the last bottle....
isnt there like a overfill bolt where u fill the oil so i can throw in 3quarts and the excess will drain out? (like i thought it was the bolt the dealer uses cuz they pump the oil in)
[#] Jun 18, 2008 02:58pm
Reg'd: Apr 17, 2006
THE SHADOW
Yeah, it's all labeled in the DIY thread posted below:
[#] Jun 18, 2008 08:27pm
blue
Reg'd: Jan 10, 2008
Oil Changer
does the mobil 1 sytnthetic 75-90 work on our cars cuz it says we could use GL4 OR GL5 and i know mobil 1 is GL 5
[#] Jun 18, 2008 08:44pm
Reg'd: Apr 17, 2006
THE SHADOW
Some use it but GL-5 is not meant for synchro style transmissions. It's best in fully meshed gear boxes like in motorcycles. GL-5 tends to make a little more "noise" during shifts when used in automotive transmissions calling for GL-4.
[#] Jun 18, 2008 08:50pm
blue
Reg'd: Jan 10, 2008
Oil Changer
okay thanks ans where do i get the amsoil cuz i see the local auto parts dont have it
[#] Jun 18, 2008 08:53pm
Reg'd: Apr 17, 2006
THE SHADOW
Salvo is the only place around my area but you can order it directly from their website. Prices are almost identical to local retailers.
Quote:
The difference in GL-4 and GL-5 is that GL-4 gear lubes have half the extreme pressure additives of GL-5. Because the gear types in manual transmissions do not necessitate the use of GL-5 gear lube, GL-4 is the correct recommendation called for by most OEM’s when gear lube is required.
[#] Jun 18, 2008 08:55pm
blue
Reg'd: Jan 10, 2008
Oil Changer
why doesnt anyone sell them if they are that good
[#] Jun 18, 2008 09:03pm
Reg'd: Apr 17, 2006
THE SHADOW
It's up to the manufacturer and how they want to label their products. It's not a retail type product but one oriented more towards racing.
[#] Jun 18, 2008 09:07pm
blue
Reg'd: Jan 10, 2008
Oil Changer
oh okay
[#] Jun 18, 2008 09:13pm
CivicEater
Reg'd: Nov 23, 2004
Detailer
i use the mobil 1 75-90 gear oil and shifts are def smoother than stock, and i used 2.5 quarts. Dont know about other products but im happy with the mobil 1.
[#] Jun 22, 2008 02:36pm
TOP: Home > Performance Mods > Transmission / Drivetrain > gear oil change
