| Look At My Yellow Waterfall |
| WTB: Waterfall for 2008 tc |
| painting rims? |
| paint ? |
| complete waterfall |
neme6ix
Hey does anyone know where i can get the cheapest price for waterfall paint thaat matches my exterior? Also do i have to sand off the original paint? |
http://www.automotivetouchup.com a light sanding is recommended if your not using krylon fusion paint. And the search is your friend. :mrgreen: ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
MacGuy87
automotivetouchup is having site problems.. i havnt been able to order paint from them for 2 weeks now.. ![]() 2006 Scion tC |
Take4roll10
I got mine from paintscratch.com |
Sensazn
automotivetouchup.com is the place to get oem paint! CarSponsorships.com |
Paintscratch.com does have great paint. I got my first BSP can from them, and it matches perfectly. Their nozzles are a little cheap though. Automotivetouchup.com is a little cheaper and of equal quality. Paintscratch is only cheaper if you need to get large quantities of paint. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
Sensazn
If you say their tips arent the best, then I'd have to say automotivetouchup has better tips. Very good spray tips if I must say. CarSponsorships.com |
1ucky11
What color is the stock waterfall? I want to match the rest of my trim in that color. |
13juan13
what type of paint does it have to be ? i'm kind of confused . |
^^The paint we were referring to is colormatched to the outside of the car but in a spray can you you can do interior pieces and other little color matched projects. If you're not color matching then Krylon Fusion is the way to go. It bonds to plastics with no real prep work required. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
baldovi08
So krylon fusion, you think Home Depot sell that Kind of stuff? lol |
Yep. Walmart too. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
Blckdouttc
got my krylon fushion for plastics at walmart ![]() 2006 BSP tC |
rocketpants
Hey guys I was painting my waterfall console and accidentally a lil bit of the paint got onto my temp control knob because the painters tape apparently had a small slit in it. So now there are tiny specks of black paint on it... What can I do to remove that little bit of paint? Worst comes to worst I'll just paint the gauge as well then... |
Kurisutaira
^^the AC knob pulls straight out u can take it off and paint it another color if u want. just if u do make sure to put tape on that lil lens where the position indicator will be that lights up. if u want it to just stay the way it was u can sand it back down and there is a flat silver u can get. its not a perfect match to the interior but its close. u can always try that if u like. also if u take the knob off make sure u tape up the area where it was b4 u paint the waterfall ![]() "This is what happens when an unstoppable force meets an unmovable object" |
