| Short Shifter on Automatic |
| launching in an automatic. |
| Changing ATF transmission fluid? |
| Justin's Performance Center....his pride and joy |
| Reverso.net (Free automatic online translation service) |
SciTown_Scicotic
Reg'd: Jun 12, 2008 Window Washer |
Does anyone know if any exist for tC's? I have the tC RS 4.0 and its an auto. I want to throw a turbo on but im affraid that my trans wont be able to handle it. Any advice other than "shoulda got a manual"? |
java09
Reg'd: Aug 05, 2007 Scion Guru |
autos are fine.. manuals are funner! haha but yeah torque converter.. tranny cooler is the full extent ive seen of mods to auto trannys. good luck though! ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
SciTown_Scicotic
Thanx for responding. So you think the stock auto trans would be able to handle a turbo as long as I had those 2 tranny mods? |
java09
there are many boosted autos! you just dont have the ability to push as much power as manual transmission. and with those two mods you will be fine in the 230-250whp range! ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
SciTown_Scicotic
Im thinking about 300'ish HP range. I see a lot of turbos out there for tC's and just thinking about what effects it would have on my motor and tranny. |
java09
300 isnt possible on auto trans sorry man.. like i said 230-250 is max what you will see. ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
It's not possible without a lot of work. I have yet to see anyone build the tranny to be able to handle that much power. I may do that myself if mine goes... Put in a high stall torque converter too so I can launch better. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
edit: ^ Ahh, there you are Damn, I'd trade my manual for their auto anyday, haha. ![]() "I have an idea! An idea so smart, my head would explode if I even began to know what I was talking about." - Peter Griffin -- Want to post a "For Sale" thread? Check out the rules first. |
java09
^^there he can inform you more specifically since hes on auto trans! **turns over to krdshark! ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
SciTown_Scicotic
you recommend any good ones? |
The only thing you really need right now is a tranny cooler. That'll help you keep the transmission holding. However, you're not going to make as much power as a manual tC. You lose too much in the transmission. Still, Turbo autos are MAD fun! Putting in a high stall torque converter = building the tranny... Not something I'm experienced with yet. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
java09
any good what? turbo kits? or upgraded torque converters? ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
SciTown_Scicotic
Torque converters and turbo's now that you mention it. Also with these mods, how will it effect the motor and trans over time? |
java09
force induction of any kind will cut your motors life sometimes in half.. (depends on how often you boost and the ammount of boost you are at) ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
Not necessarily. It will take a bit more maintenace but you can keep your motor running fine just as long. Take a look at Dezod - they make a kit specifically for automatic tCs. I went with GReddy which isn't made for autos, but with a little bit of finagling, i got it to fit. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
java09
im sorry but you are wrong the added compression and wear and tear that boost creats significantlly lowers your motors life. its more maintenance, yes... but still puts much more wear and tear on the motor. ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
I'll agree that it lowers the life, but how much is significant? I've been turboed for over 30k miles with no engine problems. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
java09
not that significant! haha instead of possibly getting 400k out of the you might get 250.. which is a lot on the long run! ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
java09
^^i would also like to add that i based that above number on high boost and boosting alot.. boost levels and level of aggresion in your driving will determine the longevity of your motor/trans. ![]() BOOSTED BY: TURBOTOYOTAS! Need Something Installed in Hawaii? Click Me! |
mospeedtc
Reg'd: Mar 19, 2007 Master Mechanic |
Tranny cooler is usually all u need until u start adding more ish and turing up the boost the you may wanna go to a place like level10 that can build you a performance trans if you have the money and desire. was boosted for 35K before my motor blew(due to my error not the kit) tranny holding for 40K and so far so good BIG CHANGES IN 09' NEED: STOCK FRONT AND REAR BUMPER |
falkore24
Reg'd: Mar 30, 2008 Master Mechanic |
I've heard more bad than good about Level 10. I think you'd be better off dealing with Dr. Evil transmissions .... it'll cost about $5k |
Beckaz_tC
Reg'd: Feb 26, 2008 Scion Guru |
I have a friend who has an auto with a turbo, one of the fastest tC's I've seen so far. http://youtube.com/watch?v=sEuFIxcaHIA http://youtube.com/watch?v=odzQW8_YyKo |
How fast? heh. I know plenty of tC's faster than me... Munch's 11 second tC... heh. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
Beckaz_tC
Here's another one 0-60 Automatic Dezod Turbo http://youtube.com/watch?v=e5VG0BybFeY |
That's not as fun to watch as my 1/4 mile run ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
