| DIY: Shaving The Rear Garnish Emblem |
| brake pads and rotors |
| Question about badgeless grill DIY |
O5_TRD_tC
Reg'd: May 16, 2008 Vehicle Designer |
Since gas is so expensive, I made this DIY for you guys to save money! Disclaimer: First of all I am not responsible if you break your own car. This is simply a guide to help you along your install. ![]() ![]() Tools/materials: -6" C-clamp - 14mm Socket wrench -Breaker bar to break lugs nuts loose -And New pads DUH! 1) Once you have your front rims off, grab your 14mm socket and completely take off the top bolt. ![]() ![]() 2) Swing the inner caliper away from the rotor. ![]() 3)Note the positions of the pads and gently remove them. ![]() 4)Remove the two metal plates and clip off of the old pads. ![]() 5) Before reinstalling the metal pieces and clip. You want to add some grease on the BACK of the NEW pads. ![]() 6) Reinstall the metal pieces. 7) Repeat steps of second pad. (2 pads per rotor) 8 ) Grab you C-clamp and slowly turn the Brake piston back in. (1 turn every 10-15 secs. You want the piston to sit back flush. Afterwards you can now remove the C-clamp ![]() Note: You might notice a bit of brake fluid oozing out on top in your engine bay. Nothing to worry about just get a rag and wipe it off. 9) swing the inner caliper back in and HAND tighten the 14mm bolt back on. 10) Repeat for other side. 11) Start the car and check the brake fluid level. It should still be full. If not add some brake fluid. 12)Follow the bedding/brake-in process as outlined by the manufacturer of the pads and/or avoid hard braking for the first 100 miles 13) Your done and you just saved yourself a $100 at least by doing it yourself! Comparison New vs. Old: ![]() enJoy! -Alan The 4 LED_Headz: Ed (etli), Trung (SquallLHeart), Alan (O5_TRD_tC), and Paul (Dakine) |
java09
Reg'd: Aug 05, 2007 Scion Guru |
nice! short and simple. A+ from me. 2008 Turbo Scion tCizzle POWERED BY TURBOTOYOTAS! 310WHP, 272WTQ more to come_.. |
O5_TRD_tC
Its very easy to do. If you dont have the tools. Barrow them from family or friends. You can buy a C-clamp at home depot and return it afterwards if you dont want to keep it after the install. The 4 LED_Headz: Ed (etli), Trung (SquallLHeart), Alan (O5_TRD_tC), and Paul (Dakine) |
A brake pad spreader would work better than a c-clamp. I use this, myself - it doesn't scratch up the caliper like a c-clamp can. It's better to use the pad spreader if you've got painted calipers. http://www.napaonline.com...n=Disc+Brake+Pad+Spreader ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
07sctc
Reg'd: Feb 16, 2008 Tech Advisor |
nice diy. i will use it when i need my pads changed. is it the same for the backs also? the first time i changed brake pads i didn't know the trick of using the c-clamp or the spreader. i ended up disconnecting the brake line and having to bleed them and all that. what an @ss that was. but you only learn by tryin. by the way...whats an average milage to have to do this? i have about 30k, but haven't noticed any problems in brakeing. beware of the mad sciontist ! ask me your car audio and electronics questions!! a little signature love for good sellers.... FULL TBL KIT! HVAC/GAUGE LEDS garage1217.com HID's WHEELS discounttiredirect.com (speak to Justin) TINT (Car Show in Anderson, SC BEST Tinter Around) |
Check the pads themselves. If it's getting down close to the backing, it's time. I Changed over to my Stoptech Stage II @ about 15k miles, maybe 20k. I still had about 1/3 pad left on the stockers I think. I only got in 25k miles on my Axxis ultimates cuz they're high bite. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
I used to use a tool similar to a C-clamp but now I get lazy and just jam a flat head screw driver between the piston and the pad while it's on the bracket and compress it that way. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
java09
^^ GET errrr DONE! edit for the must have: 2008 Turbo Scion tCizzle POWERED BY TURBOTOYOTAS! 310WHP, 272WTQ more to come_.. |
O5_TRD_tC
A C-clamp works fine. Improper compressing the piston may damage your ABS system. Average mileage to change your front pads is ~30k You go throught about 2-3 sets of front pads before the rear. I imagine the rear pads are the same, just smaller. The 4 LED_Headz: Ed (etli), Trung (SquallLHeart), Alan (O5_TRD_tC), and Paul (Dakine) |
Depends on your braking system. I went through rear pads just as fast as the front with my Stoptech Stage 2 ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
most cars have their front brakes wear out faster.. just due to the fast that most of them have a larger bias up there when stopping... (hmm... lol).. weight of car.. inertia/momentum/physics thing? anyway... also keep in mind when compressing the piston.. to go slowly! LED questions? AIM: 'SquallLHeart TN' LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
vastano1
Reg'd: Sep 06, 2006 Godlike Advisor |
the rear pads are easier to do...its just has the one bolt...then u turn the caliper to get to the pads...then change the pads and ur done...same c-clamp needed... click the link, donate some money to help improve our site/community CLICK ME TO DONATE AND HELP SQMK MAKE OUR SITE BETTER |
Yup This DIY is great for pads only. I have been meaning to get a full DIY together for pads/rotors but just never had time. Rotors would be just one extra step and that is to use a 17mm socket to remove the front bracket and slide the rotor off. The rear doesn't require bracket removal so the rotor will come off after you take the pads off. Just have to adjust the parking brake after that. Stickified as well. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
OldJersey
Reg'd: Jan 09, 2007 Vehicle Designer |
8 ) Grab you C-clamp and slowly turn the Brake piston back in. (1 turn every 10-15 secs. You want the piston to sit back flush. Afterwards you can now remove the C-clamp ^thats the only thing im worried about |
Why? That's easy. Just push it in slowly and when it stops, you're done. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
OldJersey
oh... and u use a screwdriver?.... the guy at the dealer told me mine are down to 2mm and ihave 16k on the car... does it sound legit? |
2mm is REALLY low for 16k unless you do a lot of stop and go and heavy braking. Yeah, I use a screwdriver ![]() Ignorance is bliss....305 fo life!...haha...Poser |
OldJersey
wait so u stick the scredriver in before unbolting the calliper and then theres no need for it after you change the pads and put the calliper back on? |
Actually that's not really needed - you can turn it in at a decent rate. Just uncap the brake fluid resovoir (Master cylinder) and make sure that it's not too full so you don't push fluid out. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
Yeah, the piston is already compressed so no need to compress it again. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
pooorboi
Reg'd: Jul 30, 2005 Detailer |
you may want to have a 17 mm cresent wrench ready. the slidign bolt always turns on me when i am putting my calipers back on... no one mentioned that tho... is there something wrong with my car? |
OldJersey
i did it the other day and i am so glad i didn't spend 250 at the dealer for it, rather 49bucks for the pads... only thing is i chipped my caliper paint so be careful, i can just touch it up though |
If it's that driver's side, I think your caliper is sticking on the slides. That's what is wearing your pads so fast on that one side. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
rohbocop
Reg'd: Sep 09, 2008 Tire Changer |
how many turns of the c clamp do u need till its flush? |
as many as it takes... LED questions? AIM: 'SquallLHeart TN' LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
