CrashUSAF
Reg'd: Apr 17, 2008 Godlike Advisor |
This is by far the sexiest head unit I have ever owned. It goes for around 750 dollars at retail, but got it on ebay for around 390. This head unit has so many damn options, I dont know what to do with it yet. Crazy powerful too! This thing pushes my subs to a level my other Kenwood decks could never really get to. I HAVE to be hitting over 130 db right now with this deck and 2 Alpine type-R 12s. Im using a Kenwood X1R as well, 2400 watt max amplifier. So far, this has been the best and most feature filled head unit I have ever owned. You can customise every single thing about the way this unit sounds. It is for pure performance. The visual on this unit is great as well. There are 2 video backgrounds built into the unit, however you can download other backgrounds for it and download to the head unit. There is a built in hard drive which allows you to hold nearly 200 songs on the cd player. It is USB and BlueTooth compatible. As well as Ipod and XM satellite ready. For the head unit, I give this a 9 out of 10. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Prey2k8
Reg'd: May 27, 2008 Detailer |
post some pics. |
armygirl718
Reg'd: Dec 19, 2007
Just Keep Swimming! |
do u have static on the radio?? I love my unit but i still get some static on the FM station ![]() http://www.itsmyscion.com/armygirl718 http://www.myspace.com/navsegdamaskva |
CrashUSAF
Havent tried it out yet Armygirl but Ill let ya know. Here are some pics of the install. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Luckily after this install the deck still fits in far enough that I can use the Scion radio cover. It fits SLIGHTLY akward, but works perfectly. I have the USB cable routed to my glove box so it will be hidden and out of plain sight. The unit has a tilt feature on the motorized faceplate, but its really not even used because of the natural angle of the install. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Looks good! That's the same way I routed my USB cable. Brilliant! Have a guiness. ............... ![]() ![]() ![]() Donate or one of these adorable kittens WILL DIE! |
CrashUSAF
Frank, we rock. Great minds think alike. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
SkyWarnF5
Reg'd: Feb 01, 2008 Window Washer |
hi,, where did u get the new piece that the new radio fits in since the stock HU is 4" thick ? |
CrashUSAF
I picked the dash kit up at my local car audio shop. Most shops will either have this piece in stock, or can order it for you fairly quickly. If you do not have a car audio shop nearby, try www.crutchfield.com or www.sonicelectronix.com ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
