| Just ordered Agency Power braided lines and Techna fit clutch line |
| Techna-fit stainless brake and clutch lines |
| Clutch issues?? |
| FS: BRAND NEW COMP CLUTCH STAGE 3!!! |
| Pedals |
RuniCtC
Reg'd: Apr 02, 2008 Tire Changer |
I need to adjust my clutch pedal to engage sooner(starting at the floor in an upward direction). I recently had a new clutch and flywheel installed, and the clutch engages with the pedal nearly all the way at the top. There is a way to change the engagement, can anyone help me with this? |
That's how the stock engagement is setup. You only need to depress the clutch about 2-3 inches to full disengage the clutch. It's part of the hydraulic system with the slave cylinder so to change the distance to be closer to the FLOOR, you would have a little bit of work to do. To change it and make it even higher than stock (closer to the DRIVER), then there's a DIY on Scionlife I can pull. What exactly did you want to do? http://www.scionlife.com/forums/viewtopic.php?p=1071877 ![]() Ignorance is bliss....305 fo life!...haha...Poser |
CrashUSAF
Reg'd: Apr 17, 2008 Godlike Advisor |
I would def like to make mine slightly higher, I wonder how difficult it is to do. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Realistically, the way ours is now is one of the highest I have seen in the car industry. BMW/Audi/Porsche seem to either be at the same disengagement position, if not lower than ours. Honda's are close if not a little lower as well. You have to allow for a little bit of slack due to the pedal being recoiled by a spring mechanism, but the hydraulic portion would require a new slave clyinder and clutch fork possibly, for an even higher disengagement. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
CrashUSAF
I have to push the clutch almost completely to the floor sometimes to get the sucker to engage. I want it to be maybe about 2 or 3 inches from the floor. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Are you on a stock clutch? If so, that's extremely odd to have to go anywhere close to the floor for full disengagement. Your clutch should release with about 2-3 inches of depression from the default position (up). If it takes the clutch pedal the full length of travel to release the clutch, then you may want to take it back to the dealer (unless they changed the engagement/disengagement range on the newer models). ![]() Ignorance is bliss....305 fo life!...haha...Poser |
CrashUSAF
Its not ALL the way to the floor, but I have about an inch of room from the floor until it completely disengages. Im not sure, but I do know that I want another inch or so from the floor. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
That's pretty low for stock. Mine's always been really high and it's great b/c while racing, I can shift pretty quick without having to take the pedal near the floor at all. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
CrashUSAF
Exactly, a little more room would rock for me. Im not sure what the deal is, but it needs to be changed for sure haha. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
clutch
Reg'd: Jun 20, 2007 Tech Advisor |
I always push the clutch all the way to the floor lol...is that bad? I learned to drive stick with a ghetto 92 honda accord haha and if you didn't push to the floor then nothing would work |
No, that just makes sure the clutch is fully disengaged from the flywheel and allows the gear selector to move to the higher/lower gear smoothly. DELETED OFF TOPIC THREADS: Diego, I PMed you my answers. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
