| Where do you get scion decals? |
| My Decal Design |
| tribal decal on rear of car |
| Custom Window Decal, Questions & Ideas? |
| Where do i get those decals i keep seeing? |
ScionSteve615
i jus wanted to know if i were to get a decal for my tc would it be tough time removing the decal in case i wanted to change it? thanx |
MUStC
If you don't like it later on all you'll have to do is get a razorblade (if its on glass) to take it off. If its on the body/ painted area your best bet is your finger nails so you don't scratch it up. Then take some Goo-gone and a rag to remove the sticky stuff left over. Hope that helps. ![]() ![]() |
KvizzeL
Couldn't you just use a hot gun, hair blow dryer or anything and the decal will easily be peeled off? I've only tried this on glass, so would it affected the paint or anything? |
JBoy510
i work at a sign shop and for paint it is best to use a hot gun and your finger nail to get it off initially to get a grip and from there peel so you dont leave the sticky residue. for glass like someone said, start with a razor blade to get a good grip and peel from there. if you use a razor through the whole thing you will get lots of residue. then get some windex or whatever and clean the rest off. if you have had the sticker for a long time there will be an outline. use the razor to scrape it off then clean. (you might have to repeat it a couple of times) So what if my girlfriend drives a Supra, I'm more sexier than she is! =) ************* CHECK OUT MY GALLERY ************* http://www.clubsciontc.com/jboy510/gallery-8 |
youngflyer
sorry for thread jacking but where do you get these decals from, ive been looking for a long time! ThE JeWiSh PiMp |
TheFantasticG
Pft. You guys are so wrong.. Want to get a decal off of paint or glass? 40grit sandpaper does the trick 60% of the time, every time. ![]() |
I used a razor blade. That's what Goo Gone is for!
Mine is my club sticker... Plus 2 local groups. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
hahahaha, "That doesn't make sense."....hahahahahha ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
youngflyer
does anyone know where to get the "SCION" sticker for the deflector ThE JeWiSh PiMp |
^^randode.com, but I'm not sure if you can get different colors. The one in the pic is pink... ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
youngflyer
i forgot bout that website but it only looks like the have one color available! ThE JeWiSh PiMp |
2007TC
I had silver SCION wind deflector decal...i wouldn't get silver again...because during the summer the wind deflector gets way too HOT and because of that i have noticed that there was lots of brownish looking spot all over that decal.. so i would recommend to get other color but silver. ![]() ~Tony~*tCSP* tCStreetPerformance.com |
That's what I was wondering too. Shoot them an email and see if you can choose a color. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
Crash
Silver would look great to match the clubsciontc.com vinyls!!! ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Blckdouttc
randode.com, when u click add to cart, u can choose from liek 10 colors, for removal, use a razorblade and it comes off like nothing, if theres any sticky stuff left, use goo gone and a paper towel ![]() 2006 BSP tC |
