Home > Performance Mods > Transmission / Drivetrain > short shifter?
short shifter?
tcpoppinn23
Reg'd: May 12, 2008
Window Washer
im looking for a stage 2 short throw shifter that the knob will sit real low, and i new boot also, i want the knob to sit real low though caue i dont like how the knob on the shifter sits up so high, any ideas
[#] May 12, 2008 09:23pm
Reg'd: Apr 17, 2006
THE SHADOW
TWM stage II (if you want a low height) and then hit up RedlineGoods (I think that's the name of the vendor....check the vendor sales forum) for a new boot kit.
[#] May 12, 2008 10:13pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
they have stages for shifters too????
[#] May 12, 2008 10:19pm
Reg'd: Apr 17, 2006
THE SHADOW
Only some manufacturers. TWM has a stage II but I've never heard of a Stage I by them...haha...May just be a name for them.
[#] May 12, 2008 10:20pm
Reg'd: Apr 17, 2006
THE SHADOW
Oh, also, just remember that the lower the shaft, the more the throw will be to shift into gear. Granted, it'll still be reduced from stock, but if you get a short shifter with an only "slightly" lowered shaft from stock, the effort to shift will be minimal compared to a short shifter with a really short shaft.
The further your hand is away from the pivot point, the less overall effort (and more leverage) you have in the shift.
[#] May 12, 2008 10:22pm
lee_tc
Reg'd: Jan 12, 2007
Vehicle Designer
do u get more porformacne form shortshifter i know its of topic but just a lilo question
[#] May 12, 2008 10:23pm
Reg'd: Apr 17, 2006
THE SHADOW
Gear engagement is a bit easier so you reduce time between shifts.
[#] May 12, 2008 10:24pm
BoostHerWay
Reg'd: Jul 06, 2007
i am so glad i didnt know that going into buying a shifter i had no idea about i would have been even more stupid about it lmao
[#] May 13, 2008 12:48am
Dr_Isotope
Reg'd: Sep 02, 2005
Chief Mechanic
TWM stage 2 isn't even very low. I can go an inch lower... if that's what you're into.
[#] May 13, 2008 01:19am
Reg'd: Apr 17, 2006
THE SHADOW
Didn't realize you had a lower setup.
O.P: Go with Dr. Isotope's setup. More reliable and he does the hard work of the shaft install for you. You just replace the whole cage
[#] May 13, 2008 08:28am
BoostHerWay
Reg'd: Jul 06, 2007
X2
[#] May 13, 2008 10:26am
TOP: Home > Performance Mods > Transmission / Drivetrain > short shifter?
