| DIY: Shaving The Rear Garnish Emblem |
| Question about badgeless grill DIY |
| DIY: Hormel Chili |
| DIY: LED vent install |
rrimportracer
Reg'd: Feb 28, 2006 Godlike Advisor |
So Ive been getting questions over questions on how to do the springs install and I decided it would be easier to just do a DIY and answer all the questions there. First off this DIY is done at each persons own risk. I am in no way responsible for anything happening to YOUR car unless I was physically there installing the springs myself Necessary Tools needed: 1/4", 3/8", 1/2" ratchets 10mm, 12mm, 14mm, 17mm, 19mm-3/4", 22mm-7/8" sockets 14mm, 22mm-7/8" open wrench Phillips screw driver Flat head screw driver Hammer Breaker bar Spring compressors (2 minimum) Long pipe, or shovel Knife Tools that would make the job easier Air compressor Impact drill Compressor hose I always start with the rear because they seem harder to do than the front. 1. Lift the car up by the rear ![]() 2.MAKE SURE YOU USE JACK STANDS!!! I dont know how many times Ive heard of a car falling on someone because all they used to hold the car up was the jack. Please they are relatively inexpensive and can save a life or a limb ![]() 3. Remove the interior trunk flooring, and I also removed the side panels to make it a lot easier to access the hidden shock bolt there are 3 things holding the side panel in 1 10mm bolt near the tail light, one clip that pops out with a screw driver, and a phillips screw up near the top all pointed out here ![]() ![]() 4. once the sides are removed remove the piece that covers the back seats by prying open the plastic clip to get access to the 10mm bolts, one on each side ![]() ![]() 5. loosen the 3-14mm nuts at the top of the shock ![]() 6. Next remove the 19mm-3/4" bolt here at the bottom of the shock. This bolt is really tight and would help if you used either air tools, or a breaker bar you will need to use a screw driver and hammer to make the bolt start coming out of its hole because its in there pretty snug ![]() ![]() ![]() 7. Once removed, remove the 3-14mm nuts from the top completely ![]() 8. This is where you need the long pipe, or shovel. You need to use it to push the lower control arm down to make room to remove the shock ![]() It can be tricky to remove this, so be patient and wriggle it around till you get it out. 9. Loosen this 17mm nut just a little NOTE: I REALLY MEAN JUST A LITTLE BIT, IF YOU DO IT TO MUCH IT WILL SHOOT OUT POSSIBLY INJURING SOMEONE ![]() 10. Place the spring compressors onto the spring equally distanced from each other and tighten down Again, air tools make your life so much easier! ![]() 11. Once removed its time for the new spring to go in, this part can also be a little tricky, you have to align the bottom hole of the shock with the top part where the bolts stick out ![]() Use the spring compressors again so you can install the top part back on ![]() And there you go! ![]() Re-tighten the 17mm nut at the top of the shock ![]() 12. Install the shock/spring back onto the car and make sure everything gets tightened: the 19mm at the bottom, and the 3-14mm's at the top 13. Repeat steps 5-12 for the other side of the car. Here is a pic of the shock, and bolts that must be removed ![]() Put the tires back on, and lower the car back down once everything has been checked and rechecked to make sure its all tightened ![]() ![]() And there you go, the rears are done!! ![]() Now to move on to the front of the car, which I personally think is easier that's why I do it last. 1. Start off by removing the clips from the plastic cover on top ![]() ![]() 2. Then loosening the 3-14mm bolts on top of the strut tower with a 14mm open wrench ![]() 3. Remove the 12mm bolt holding the brake lines down ![]() 4. Remove the 17mm nut holding the sway bar end links ![]() 5. Now remove the 21mm-7/8" bolts from the bottom of the strut tower, these are on very tight and air tools would help, if not a breaker bar also works ![]() 6. Go back to the top and remove these bolts completely ![]() 7. Wriggle the strut out and put the spring compressors on, loosening the 19mm nut at the top of the tower Again loosen just slightly to make it easier once the spring is compressed ![]() 8. Once removed the bump stop needs to be cut depending on what springs you have the amount needed to be cut will differ ![]() I didnt have a pic of mine with the new springs installed but this is what it should look like with the new spring in ![]() ![]() 9. Put the strut back in tighten everything down and repeat steps 1-8 for the opposite side of the car. Once you have checked everything to make sure its all tight put your tires back on and lower the car back down. Depending on how low your drop is, you might have to put the jack on the sides and take each stand out individually. My car with s techs, the front bumper was to low for the jack to fit under it. Finished pics of my car with s-techs Before: ![]() After: ![]() ![]() Jon's car on saturday ![]() I know this wasnt the most detailed DIY but it should let everyone know what needs to be done EDIT: in my diagram for the front suspension I accidentally put that the bolts on top of the strut tower are 17mm, they are not. There are 3 14mm bolts not 17mm ![]() myspace.com/asphalt_photos check us out!!! |
vastano1
Reg'd: Sep 06, 2006 Godlike Advisor |
almost makes me want to take off my springs and put them back on by myself...great write-up click the link, donate some money to help improve our site/community CLICK ME TO DONATE AND HELP SQMK MAKE OUR SITE BETTER |
rrimportracer
hahaha.. Ive done 6 installs on the Tc, I must say I do enjoy doing it, and have gotten it down to about 2.5-3 hours of work with a little bit of help from my little brother ![]() myspace.com/asphalt_photos check us out!!! |
rrimportracer
bump for people that missed it since I posted this late last night ![]() myspace.com/asphalt_photos check us out!!! |
Reg'd: Dec 08, 2005 |
sticky thanks Allen, this is great |
Great write up!!! It's about time we had our own. Thanx for steppin up! ............... ![]() ![]() ![]() Donate or one of these adorable kittens WILL DIE! |
LA_Tc_Rider
Reg'd: Nov 10, 2007 Detailer |
damn ur my mechanic whenever i need something installed thats too complex for me, u should open up a shop with my sisters bf, yall would make hella money |
dasiknes803
Reg'd: Jul 17, 2007 Chief Mechanic |
Not to rain on your parade but for the rear i have learned that it is more safer if you dont remove the 3 bolts on the top. The way i have installed springs, I dont even use a spring compressor. I use a jack. This is just what i do and its easier for me this way. Good write up though. Im glad someone finally did this. ![]() Check out http://www.racingsolution.com/ Also Check out my car domain: http://www.cardomain.com/id/dasiknes803 |
da_grouch
Reg'd: Apr 18, 2008 Master Mechanic |
great write up allen "thumps up" |
CrashUSAF
Reg'd: Apr 17, 2008 Godlike Advisor |
Is it not possible to just do 1 wheel at a time? I figured you could just do them seperately, so only 1 spring compressor would be needed. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
N8thegreat22
Reg'd: Sep 10, 2007 Tech Advisor |
Really Nice! Now we finally have a good DIY for springs. I should be doing this on Saturday so this will really help. My only question is how dangerous would you say the install is? I ask because my Dad talked to a mechanic he knows and he told him that if you don't know what your doing you can really get hurt. Especially when getting the springs compressed and off. |
rrimportracer
This is the way I was taught by my dads buddy that owns a shop, so this is the way Ill keep doing it. There is a saying that when two roads are available, the one most known is the shortest and easiest... or something like that lol I know this way and Im sure your way works too but this is what I was taught. If your generally knowledgeable when it comes to car stuff I would say this is probably a 3-4/5 rating job if its your first time doing it. For me personally since I've done 6 of them its probably a 2. If anyone feels I left anything out please pm me and ill update the DIY as I see fit. ![]() myspace.com/asphalt_photos check us out!!! |
rrimportracer
you still need 2 spring compressors if your doing one wheel, look at the way i have the spring compressors set up, youll see that I have two of them. If you do not have two you risk causing damage to the springs, and maybe even injuring yourself. Just go to autozone and rent out spring compressors, they come in a pair anyways and cost $40 until you return them then you get all your money back ![]() myspace.com/asphalt_photos check us out!!! |
danyo
Reg'd: Mar 05, 2008 Detailer |
great DIY. quick question, are the pictures for the front install from another diy cuz i think i've seen those pictures about 3-4 years ago when i did my springs. absolutely true that everyone keeps askin spring install questions but don't go out and search for one. unfortunately, i have not seen a perfect tC spring install guide so this one will help others more. good job! |
Good job bro. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
rrimportracer
thanks, hope to be doing some more diys in the future ![]() myspace.com/asphalt_photos check us out!!! |
O5_TRD_tC
Reg'd: May 16, 2008 Vehicle Designer |
nice DIY! The 4 LED_Headz: Ed (etli), Trung (SquallLHeart), Alan (O5_TRD_tC), and Paul (Dakine) |
MacGuy87
Reg'd: Mar 24, 2008 Chief Mechanic |
Very nice! There is more work to it than I imagined! lol... How long did this take you? About how long do you think it would take the average person who has never done this before? ![]() 2006 Scion tC |
danyo
my very first time to do any car mod were springs that took me about 9 hours without an air compressor, a c- DIY i found, and yah... =]. Takes about.. 3 hours now with little breaks. |
MacGuy87
Thats good! i dont have air compressor or air tools... lol.. I got hundreds of other tools tho! lol.. I dont think i'm rdy for something like this yet, I dont have anyone to help me right now anyway and i wouldnt want to do it alone.. lol ![]() 2006 Scion tC |
Amanda22
Reg'd: Jul 13, 2008 Oil Changer |
about how long does this take? My friends gonna do them for me and I was just wondering |
JRod_TC
it all depends if ur friend has an air gun and a lift or not. ![]() http://clubsciontc.com/fo...ion-System-Launched-.html |
![]() "gonna wash my car before i take a nap.. can't rest well knowing i've got the entire cast of A Bug's Life on my bumper" - Vicious -- Want to post a "For Sale" thread? Check out the rules first. |
Amanda22
Yeah he has both. |
blaszczykl
Reg'd: Jun 16, 2005 Detailer |
first springs I did was 7hrs.. the 2nd spring was 5hrs.. thats by myself taking my sweet time.. It will take atleast 7hrs for someone that didnt do springs before... I just think do your research before digging into it.. remember the rear springs have to be align perfectly or the wont fit |
