Home > Visual / Audio Mods > Wheels & Tires > How to Read the Sidewall of a Tire
Reg'd: Aug 16, 2007
The graphic above shows what each letter and number on the sidewall of a tire indicates.
The following is a breakdown of the components of the size of the tire.
P
Passenger car tire. If there is no P before the size it would indicate it is a European metric tire. An LT before the size would designate a light truck tire.
205
This is the Section Width in millimeters. This measurement is taken from sidewall to sidewall.
65
This number refers to the height of the sidewall, or the Aspect Ratio. It is a percentage of the section width. In this example, you would take 65 percent of 205 millimeters and this would give you the sidewall height.
R
Radial tire construction.
15
Wheel diameter in inches.
Information Source
[#] Apr 22, 2008 01:33am
tinx_winx
Reg'd: Nov 15, 2007
Detailer
i dont get it, was this just an out of the blue thing
-i now refuse to fix this-
[img]html:http://i20.tinypic.com/6jyst5e.jpg[/img]
[#] Apr 22, 2008 01:58am
Reg'd: Mar 05, 2006
I'm pretty sure her intention was to help those who don't understand what the sidewall marking mean.
[#] Apr 22, 2008 01:59am
X_RockstaR_X
Reg'd: Jun 07, 2007
Tech Advisor
Well this helps ALOT cuz apparently I read this wrong and under-inflated my tires drastically. But luckily my friend caught it before I went to far on these tires. The bad thing is there is a little bit of sidewall damage and these are pretty expensive tires (kuhmo spt's)
Vicious wrote:
Hips?! The Celica has hips... The tC's a brick.. A sexy man brick
[#] Apr 22, 2008 02:32am
Reg'd: Aug 16, 2007
Get what? There's nothing to get. Just read and learn.
[#] Apr 22, 2008 04:10am
Reg'd: Aug 16, 2007
LOL. Glad it helps you. I did a little research so I wont make the same mistake.
[#] Apr 22, 2008 04:11am
Reg'd: Oct 21, 2005
$upervillain
I think its also worth mentioning that where it indicates the maximum load PSI, that this is not the pressure you are supposed to fill your tires to!!!! The correct pressure is written on the inside of your driver's side door on the sticker.
Even Zombies can Search...
[#] Apr 22, 2008 08:22am
VIP_tC08
Reg'd: Dec 02, 2007
Awesome information nadia, another great contribution to the forums
'08 // Flint Mica // tC
[#] Apr 22, 2008 10:17am
Reg'd: Dec 08, 2005
I'll definitely refer back to this because I sometimes forget.
Thanks Nana
[#] Apr 22, 2008 10:18am
1KawaiTcInMS
Reg'd: May 21, 2008
Tire Changer
Although i knew some of the information I did learn a couple of things i didnt know thanks for posting that. I actually have to buy new tires so ill keep this thread in mind!~
[#] Jun 02, 2008 10:32am
TOP: Home > Visual / Audio Mods > Wheels & Tires > How to Read the Sidewall of a Tire
