Home > Performance Mods > Nitrous Oxide > Where's my Fuel Line???
07TouringCoupe
Baltimore
Whats up club. Me and my brother are going to install my Zex wet kit. I need to tap into the fuel line, seeing that i have a wet kit. Where is the fuel line at?
[#] Apr 16, 2008 05:52pm
brianc500
Kalamazoo
Michigan, US
It will be connected directly to the fuel rail which the injectors are connected to. Be careful to purge the system before you open the line because it still may have pressure and you'll get a nice surprise when you pop it open.
Drag image to new tab in IE or Safari to enlarge Photo.
[#] Apr 17, 2008 08:49am
07TouringCoupe
Baltimore
What do you mean purge the system? How do i do that? What would happen if i didnt and still cut into it to tee it with the nitrous line? How much fuel would i lose? Would i be able to stop it from coming out?
[#] Apr 17, 2008 03:05pm
Winter Park
it means crank the car to get out all the fuel in the system
[#] Apr 17, 2008 03:37pm
DaRkDaYz08
Mooresville
North Carolina, US
you would be fine you wont lose much....basically all it is is whats left over in the lines...the fuel pump is not on so its not supplying fuel up to the fuel rail so its no sweat just take caution when you crack it loose cause there is pressure build up in the line but as long as you got the key off it will only spray for a split second till the pressure is gone outta the line
[#] Apr 17, 2008 05:43pm
07TouringCoupe
Baltimore
ok. Thats all i wanted to know. Now. That picture a few posts up.. I need a better view of the actual line so i can tee it with the fuel line for the nitrous
[#] Apr 17, 2008 07:14pm
brianc500
Kalamazoo
Michigan, US
I'll snap a photo of mine for you later today
[#] Apr 21, 2008 04:43pm
07TouringCoupe
Baltimore
nevermind buddy. I found it... I just need the Throttle position wire and the RPM tach wire
[#] Apr 21, 2008 04:52pm
durandisse1
Spring Valley
see a performance mechanic then call it a day. 100 shot all day every day!!!!
[#] Apr 21, 2008 06:16pm
07TouringCoupe
Baltimore
No need for it. I found it and was a piece of cake to tap into
[#] Apr 24, 2008 07:13pm
TOP: Home > Performance Mods > Nitrous Oxide > Where's my Fuel Line???
