Home > User Content > DIY / Install Guides > DIY: Short Ram Intake Installation
bonaviche
Reg'd: Apr 07, 2008
Chief Mechanic
Step 1: Before starting 99% of any engine modification, you want to disconnect the negative. This is especially important for the ECU to adjust to the new intake.
Step 2: Remove the screws holding on the MAF sensor and the loosen the clamp holding the airbox to the intake tube. Remove the MAF sensor from the intake.
Step 3: Disconnect the clips holding the airbox lid to the airbox. Remove the lid and air filter
Step 4: Remove the 3 10mm bolts holding the bottom of the airbox to the car frame and remove the airbox.
Step 5: It?s time to remove the intake tubing that goes into the fender. There are 2 points where a plastic screw is holding it down, one on each side of the tubing. The plastic end holding down the intake tubing is open-ended, a quick pull of the intake tubing will take it out.
Step 6: The second one is a little hidden but a quick pull will get it out.
Step 7: Next remove the valve cover to get access to the intake vacuum line.
Step 8: Now unclip the vacuum line at the cylinder head. Retain the metal clip because you will need to use it again.
Step 9: Remove the other side of the vacuum line and also remember to keep this clip.
Step 10: Now unclip the set of rubber lines connected to the intake.
Step 11: Use a vise grip to compress the clip holding the intake tubing to the throttle body. Remove the tubing from the engine bay
Step 12: Connect the coupler between the throttle body and intake tube.
Step 13: Now connect the filter to the other end of the intake tubing with the other coupler. On the first metal clip remember to include the small metal bar that will anchor the intake in the engine bay.
Step 14: Here is that metal anchor. Screw it into the engine bay in the hole that was previously used to bolt the airbox too.
Step 15: Connect the supplied vacuum line with the stock metal clip to intake.
Step 16: Do the same for cylinder head.
Step 17: Attach the MAF sensor to the intake
Step 18: Now re-attach the negative to the battery. Make sure all the screws and bolts are tight. Now start the car and let it idle for about 5 minutes. Than take the car out and let rip!
[#] Apr 12, 2008 11:23pm
Reg'd: Dec 08, 2005
awesome, I'm glad to see more user created content lately
great DIY
[#] Apr 12, 2008 11:42pm
scionteecee
Reg'd: Dec 02, 2007
Chief Mechanic
excellent diy. i have seen many diy's made lately. intake installation is actually a fairly easy mod. just to clarify this diy is actually for SRI not CAI.
edit: mod changed the thread name
[#] Apr 13, 2008 12:04am
dqlostsoulz
Reg'd: Feb 07, 2008
Tech Advisor
Great diy...i will be using this one of these days when the intake goes down in price!
[#] Apr 13, 2008 12:57am
Reg'd: Aug 16, 2007
I installed my SRI not too long ago. Nice write up!
CLICK HERE TO DONATE & HELP MAKE THIS WONDERFUL SITE OF OURS BETTER!
[#] Apr 13, 2008 01:10am
bonaviche
Reg'd: Apr 07, 2008
Chief Mechanic
its the same thing for CAI as it is SRI, obiously the cold air intake goes through and down the bumper, so u probably need to unscrew couple of bolts, to get it throug, i like takn the bumper off, personal preference, its jus easier.
[#] Apr 13, 2008 03:48pm
bonaviche
Reg'd: Apr 07, 2008
Chief Mechanic
ok, dats kool, congrats, not to many girls can do things like this on there own...very impressed...which brand did u get..injen? how u like it so far?
[#] Apr 13, 2008 03:50pm
Reg'd: Aug 16, 2007
lol thanks.. i did have some help though, hehe.. i got the injen SRI, and custom painted it white.. i LOVEEEEEEE it.. it sounds sweet, and I notice that the car picks up speed alot quicker.
[#] Apr 13, 2008 11:50pm
bonaviche
Reg'd: Apr 07, 2008
Chief Mechanic
then i take bak wat i said bout being impressed...lol...j/p.
well im glad u like it, and im sure it sounds badass...enjoy
[#] Apr 14, 2008 04:49pm
Reg'd: Aug 16, 2007
LOL.. I said a LIL help but thanks.
[#] Apr 15, 2008 01:18am
07sctc
Reg'd: Feb 16, 2008
Tech Advisor
gonna be using this REAL SOON!!!!!!!
beware of the mad sciontist !
a little signature love for good sellers....
FULL TBL KIT! O5_TRD_tC
HVAC/GAUGE LEDS garage1217.com
HID's operatic
WHEELS discounttiredirect.com (speak to Justin)
TINT (Car Show in Anderson, SC BEST Tinter Around)
[#] Aug 19, 2008 09:48pm
TOP: Home > User Content > DIY / Install Guides > DIY: Short Ram Intake Installation
