| need amp help!!! |
| Need help |
| Electrical help needed!!! |
| My Custom Tinted TYC Tails |
| Need help fast!!! Please |
lee_tc
ok just got my tail tint its per cut...do i just put the tint on or do i have to do something first??? ok i need instruction on how to put the tint on people say that i have to get soap water and heat gun or hair dryer help |
lee_tc
i want to put them on before 12 today which is in 3 hours |
tc4metory
make sure the plastic is clean and its not too cold out but thats all I did before I tinted my mirror signals Chuck Norris is currently suing myspace for taking the name of what he calls everything around you. |
lee_tc
ok want if out side is about 35 and cold should i put them on or shouyld i wait until it gets warmer? |
tc4metory
it was pretty cold here when I did mine, so we had a hair dryer and used the microwave for about 15 seconds to make them a lil more pliable.. it prob would have been easier to wait until it was warmer out but I don't have the patience Chuck Norris is currently suing myspace for taking the name of what he calls everything around you. |
lee_tc
aaaaaaaaaaahhhhhh i cant wait too but i dont really know wat to do...so i got to warm the tint beofre putting it on?? and should i clean the lights too...man i reall want them on but its so cold!! |
tc4metory
yeah make sure the lights are really clean.. get a hairdryer out and warm up the lights and warm up the tint.. warming the tint makes it easier to work with.. I had a small spray bottle of liquid dish soap and water (what the instructions said to use) and sprayed the tails and started applying the tint, pressing down with a credit card.. it took awhile but it worked Chuck Norris is currently suing myspace for taking the name of what he calls everything around you. |
lee_tc
instructions...i didnt get any instructions :'( |
tc4metory
check around for DIYs on SL and the other scion sites.. I'm at work otherwise I would grab mine Chuck Norris is currently suing myspace for taking the name of what he calls everything around you. |
lee_tc
ok thanks....where u work how u using net and working? hahaha |
tc4metory
i work for a hospital system and for some reason all my forums are not locked.. woot woot for me!!! Chuck Norris is currently suing myspace for taking the name of what he calls everything around you. |
N8thegreat22
When I put mine on the instructions also had me get them wet with a mix of dish soap and water. This allows them to slide around eaiser so you can put them on perfect. The thing you want to make sure doesn't happen is for the water to freeze under the tint. This will cause the tint to lift away and now stay like it should. Good Luck! |
tc4metory
very good point ^^^ thats where the hair dryer comes in handy!!!! Chuck Norris is currently suing myspace for taking the name of what he calls everything around you. |
N8thegreat22
Ya I used a hairdryer which did seem to help a lot. But I was luckily enough to get mine on in 70 degree heat! Makes all mods a little eaiser. |
lee_tc
hahah thankx i just wait until it gets warmer thankx again |
N8thegreat22
^^ Can't go wrong with that lol. I think thats a good idea, it would be pretty difficult to do in the cold. Man I want a heated garage so bad! lol |
lee_tc
o yea i could do it at my uncles heated garagehahaha thankx almost for got yea i can get it on now wwoooopppyy!!! |
lee_tc
SarahAshley23
Honestly I would have a shop do it. Mine did not come out that great when I had my friend do it. It is hard to make sure you get all the bubbles out. Unless you have some kind of SUPER patience it probably will not come out as good as you want. I am having a shop tint mine for me as we speak, because I was not happy with the outcome of mine. Good luck with yours. =) |
VIP_tC08
Same here i had a shop professionally install mine, and was not happy with the outcome, i ended up custom tinting them w/ my own design, and now their perfect, i even wax them occasionally to really make them stand out ![]() '08 // Flint Mica // tC |
lee_tc
my precut was not cut right so i fuked it up AAAAAAAAAAAAHHHHHHHHHH dam going to letr the shop do it now fuk that AAAAAAAAAAAAAAHHHHHHHHHHH |
edited thread title ![]() CLICK TO DONATE & HELP MAKE THIS WONDERFUL SITE OF OURS BETTER! |
