| REVIEW: Agency Power stainless steel brake lines |
| Independant power for FOG lights |
| ????Power wire Fuse HELP??? |
| HKS hi power exhaust |
| Cigarette Lighter Power Source Not Working |
supafly
anyone have any experience with power inverters? what brands to get, what brands not to get, etc...i hear stories about some of them being noisy, some of them just not workin...where to place them, you know the deal! basically i am trying to hardwire one to the battery (i do not want to use the cig lighter) and route it to behind the dash i guess so i can stick somethin in the glovebox. any suggestions would be great! thanks1 :mrgreen: |
CaptainJack
Depends on what you want to do with it. Just make sure you don't skimp and get one that isn't powerful enough to sustain the load of what you're hooking up to it. Also, some of them have to be manually turned on every time the power cycles or if it trips so if you want to bury it in the dash you may want to consider getting one with a switch that stays on or make sure you put it somewhere you can reach the switch easily. Also, if you're going to direct connect it make sure you don't drain your battery! ![]() the devious monkey photography TEAM ECHO CHICAGO |
supafly
thanks! its just for a ps2. i was lookin to upgrade my battery too when i did it. |
If you're just going to use it for a ps2, why not just get the dc adapter and hardwire it? http://www.amazon.com/Pla...wer-Adapter/dp/B0007PHO8Y ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
supafly
how would you go about hardwiring a dc adapter? i thought you needed the inverter for it to be hardwired. |
supafly
thanks! http://www.radioshack.com...g=2&parentPage=family looks like ill be headin to radio shack sometime this week. $7 aint bad. aint bad at all. |
Nice :mrgreen: ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
Headlessmunky
My father has a truck(semi) he uses a CObra it is God like. It been stepped on and it still works had it for about 3 years and vibrations dont hurt it either. I would go with a 1500watt or maybe a 3000 so u can also run a laptop as well. ![]() Save P2P ^If you support P2P^ |
