| Competition Clutch Super Sale |
| Is this clutch any good |
| Am I Hurting My Clutch? |
| REVIEW: Techna fit stainless steel clutch line |
| 05 clutch |
carcandy
![]() Forged Ultra Lightweight Steel Flywheel The STU flywheel is recommended for forced induction and/or track and rally racing applications. This flywheel will work with ALL performance and stock clutch assemblies. Qualities of the CCI Ultra Lightweight Steel Flywheel: One piece ring gear for high durability Weight varies from 8 lbs. to 10 lbs. depending on application Well suited for Stage 3 and up clutch kit applications Stamped with 4140 plate with 2000 ton pressure at 1260 degrees CNC machined and balanced to O.E. specifications Reduced Mass = Increased Acceleration Meets and exceeds SFI 1.5 -------------------------------------------------------------------------------- Forged Lightweight Steel Flywheel The ST flywheel is recommended for naturally aspirated and/or street driven applications. This flywheel will work with ALL performance and stock clutch assemblies. Qualities of the CCI Lightweight Steel Flywheel: Preserves low end torque and drive ability One piece ring gear for high durability Weight varies from 11 lbs. to 14 lbs. depending on application Well suited for Stage 1 and Stage 2 clutch kit applications Stamped with 4140 plate with 2000 ton pressure at 1260 degrees CNC machined and balanced to O.E. specifications Reduced Mass = Increased Acceleration Meets and exceeds SFI 1.5 ------------------------------------------------------------------------------- ![]() Stage 1 - Gravity Series 2400 Clutch Kit The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel. DO NOT use with added forced induction such as turbo, supercharger, or NOS systems. The 2400 Series kit includes a Competition Clutch pressure plate, a 6 pad Carbotic high-torque performance disc assembly, all applicable bearings and the appropriate alignment tool. -------------------------------------------------------------------------------- Stage 2 - Street Series 2100 Clutch Kit This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool. -------------------------------------------------------------------------------- Stage 3 - Street/Strip Series 2300 Clutch Kit This segmented Carbon Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up. The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool. -------------------------------------------------------------------------------- IronMan Street/Strip Series 1680 Clutch Kit This assembly features our advanced hybrid iron and carbon friction material riveted to our high torque disc assembly in a six puck style. The IronMan provides outstanding stability, smooth engagement, and less wear on opposing surfaces. Offers 175% increase in torque capacity. The 1680 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Iron/Carbon buttons, all applicable bearings, and the appropriate alignment tool. ------------------------------------------------------------------------------- Stage 4 - Strip Series 1620 Clutch Kit This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool. ------------------------------------------------------------------------------- Stage 4 - Strip Series 0620 Clutch Kit This assembly, available with a six puck rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. The 0620 Series kit includes a performance pressure plate, a six puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool. ------------------------------------------------------------------------------ Stage 5 - Strip Series 1420 Clutch Kit This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. The 1420 Series kit includes a performance pressure plate, a four puck high torque sprung disc Ceramic buttons, all applicable bearings, and the appropriate alignment tool. ------------------------------------------------------------------------------- Stage 5 - Strip Series 0420 Clutch Kit This assembly, available with a rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. The 0420 Series kit includes a performance pressure plate, a four puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool. ------------------------------------------------------------------------------- 05-07 xA/xB http://www.carcandymotorsports.com/index.php?cPath=25_27_93 04-08 tC http://www.carcandymotorsports.com/index.php?cPath=25_29_98 Contact me with any questions. Greg |
carcandy
bump |
carcandy
bump |
psiewert
your link says that your account has been suspended ![]() |
carcandy
sorry, we had server issues this morning. |
carcandy
bump |
carcandy
in stock ready to ship. |
carcandy
bump |
carcandy
bump |
carcandy
carcandy
bump |
carcandy
in stock |
carcandy
bump |
Stu_Gotti
Although I didn't purchase from CC Motorsports, I have the Stage II CC Clutch Kit, it's BA! Holds great and makes for sporty feel! Scikotics Northeast Regional MFIC Army Combat Veteran - 3ID Ft. Stewart, GA ~If Wile E. Coyote had enough money to buy all that ACME crap, why didn’t he just buy dinner? |
carcandy
carcandy
bump |
carcandy
carcandy
bump |
carcandy
bump |
carcandy
bump |
carcandy
in stock. |
carcandy
carcandy
in stock ready to ship. Greg |
carcandy
bump |
