Home > Visual / Audio Mods > Mobile Electronics > Help! how do i get to the wires from my stock HU?
DEW27
Kenner
Louisiana, US
I want to hook up my system but I have no clue how to get to the wiring for my HU without tearing my car apart or breaking anything. Just got my new 08 tc 4 days ago and am not looking to try and break anything.
DEW
[#] Mar 16, 2008 01:33am
blaszczykl
Casselberry
well you dont have to tear your car apart too much.. lol...
you just have to take the arm rest off and take the HU out. the back seat just pops out. Run the RCA cable from the radio in the middle under the transmission shifter then under the back seat, and then to the trunk.... if you just putting subs in... it should not take you more than 1hr to hook it up.
[#] Mar 16, 2008 06:27am
nick06tc
You can do it really easy and not have to remove anything but the bezel around the headunit. I am not sure what headunit you have and if your using a LOC or not. But assuming you need to get to your hedunit. Pull the Waterfall console off with your fingers, no tools required.
use a 10MM socket set to remove the headunit. Do what you need ot back there. Run the wires behind the glovebox, and under the plastic piece near the door sill. Run it behind the seatbelt and through the area between the seats and side of the rear of the car. Push the wire out of site and its now to the back of the car.
Only need a 10MM socket and maybe remove the glove box, and that needs no tools.
I have pictures of how to do this all on here in a DIY.
[#] Mar 16, 2008 06:41am
DEW27
Kenner
Louisiana, US
I have the 08 stock headunit. Yea those pics would def. help out big time.
[#] Mar 16, 2008 10:14am
nick06tc
Well, the first thing is, I dont think they added RCAs to the 08 headunits. Could be wrong tho. But the older headuints did not have them, so you might need a LOC (Line Out converter).
That actually make its easy, just find the wires on the drivers side under the plastic door sill and tap the rear speakers then run RCAS.
here is a thread with some pics of how to take apoart the dash for the radio. Pretty easy.
Here is how to install a headunit I wrote up onanother site. But it shows how to take apart the dash:
http://www.xtremescion.com/forum/viewtopic.php?t=151
[#] Mar 16, 2008 06:31pm
DEW27
Kenner
Louisiana, US
I already have a LOC, so I just tap into the speaker wire under the door sill and run the rest. I appreciate your help and I will let you know how it goes and let you know if I have any questions if thats kool?
DEW
[#] Mar 18, 2008 07:27pm
nick06tc
Glad its all good. If you have any other questions just ask.
[#] Mar 18, 2008 11:49pm
TOP: Home > Visual / Audio Mods > Mobile Electronics > Help! how do i get to the wires from my stock HU?
