Home
> Visual / Audio Mods
> Wheels & Tires
> wheel offset (Explained)
Rexamerius
I was just wondering if anyone was familiar with wheel offsets because I have a Rado widebody that I want to put on, but I haven't bought the wheels yet. I know that I should be looking for wheels with a negative offset, but I don't know how to determine that. So...help?
[#] Feb 29, 2008 09:19am
Perry Hall
Maryland,
US
From Wiki: http://en.wikipedia.org/wiki/Offset_(wheel)
- Wiki wrote:
- The offset of a vehicle's wheel is the distance between the centerline of the wheel and the plane of the hub-mounting surface of the wheel. It can thus be either positive or negative, and is typically measured in millimeters. Offset has a significant effect on many elements of a vehicle's suspension, including suspension geometry, clearance between the tire and suspension elements, the scrub radius of the steering system, and visually, the width of the wheel faces relative to the car's bodywork.
Zero Offset - The plane of the hub mounting surface is even with the centerline of the wheel.
Positive Offset - The plane of the hub mounting surface is shifted from the centerline toward the front or outside of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative Offset - The plane of the hub mounting surface is toward the back or brake side of the wheel's centerline.
"Deep dish" wheels typically have negative offset or a very low positive offset.
To maintain handling characteristics and avoid undue loads on bushings and ball joints, the car manufacturer's original offset should be maintained when choosing new wheels unless there are overriding clearance issues.
Wheels are usually stamped with their offset using the German prefix "ET", meaning "Einpresstiefe" or, literally, "insertion depth". An example would be "ET45" for a 45mm offset.
Calculating the offset of a wheel is a fairly easy mathematical equation. First, measure the overall width of the wheel (remember, just because a wheel is 18x7.5, does not mean that the OVERALL width is 7.5”. It means that the measurement between the outboard flange and the inboard flange is 7.5”). Next, divide that width of the wheel by two; this will give you the centerline of the wheel.
Overall width/2 = Centerline
After determining the centerline, measure from the hub-mounting surface of the hub to the edge of the inboard flange (if the wheel were laying flat on the ground – face up – your measurement would be from the ground to the hub-mounting surface). This is your back spacing.
Back Spacing - Centerline = Offset in Inches
Inches x 25.4 = Offset in mm
:mrgreen:
Search or one of these adorable kittens WILL DIE! |
[#] Feb 29, 2008 09:41am
TOP: Home
> Visual / Audio Mods
> Wheels & Tires
Administrator
Users who are administrators.
Audio Subject Matter Expert
Users who have a special interest and knowledge of audio systems.
Auto Subject Matter Expert
These users have a special interest in how vehicles work, what's best, etc. These members continually help those asking questions, and will research if needed.
Dealer
Users who have been or are currently car sales persons / dealers..
Detailing Subject Matter Expert
Want a shiny car and don't want to bring it to a detailer? These users can help you out.
Elder User
Users who are older than 2 years old.
HID Subject Matter Expert
Users with a special interest in HIDs.
LED Subject Matter Expert
Those who have a special interest and excellent knowledge of LEDs.
Moderator
Users who are moderators on ClubScionTC.com
New User
These are new users that are less than 1 week old.
NOS Subject Matter Expert
Users who have a special interest / knowledge of Nitrous Oxide systems.
Photography Subject Matter Expert
Users skilled with cameras.
Photoshop Subject Matter Expert
Those who are skilled in Photoshop.
Popular User
Everyone knows who these users are. They stand out by being friendly, helpful, etc.
Site Contributor
Contributes to the site, in terms of features, development, products, etc.
