Home > Performance Mods > Exhaust > injen axelback help hp?
anichols1
Clifton Forge
I think im goin to buy the injen ses axelback for my 08 tc i know with axelbacks you dont get any hp gains but what if i use a different midpipe or something like that?
[#] Feb 28, 2008 11:10am
Auburn
Alabama, US
You do get a little gain of hp & ft-lbs with an axle-back but the number at the wheel is very small. Maybe about 1.2 whp.
A mid-pipe will add a little more. Basically the more you replace your stock exhaust with a 2.25-2.5 inch diameter pipe, the better the performance.
Let's not forget a nice header + s-pipe
[#] Feb 28, 2008 11:24am
SuperXero
Silver Spring
the injen helps the most when you have other mods to support it. it was my first mod, and i didnt feel much of a difference when i put it on. but when i took it off to sell it(after i added intake/header/s-pipe, i immediately felt the power loss when put the stock muffler back on.
[#] Feb 28, 2008 11:40am
Perry Hall
  • $upervillain
Which midpipe is the best is always going to be a matter of debate. Ask 5 different people and you'll get 5 different answers. I personally would recommend having a custom midpipe made at 2.25-2.5" to match the rest of your exhaust. Put either a big resonator 28-32" or two smaller ones (18"), and if your feeling froggy, add a high flow cat. Custom will be cheaper and the fitment is guaranteed.
[#] Feb 28, 2008 12:01pm
Rockville
  • The Guru
If the midpipe diameter is different from the Injen axle back diameter, would that cause power loss (rather less power gain)? And follow up, would "non matching" diameter sound different from the matching diameter set up?
[#] Feb 28, 2008 12:43pm
Perry Hall
  • $upervillain
Whatever your smallest diameter pipe on your exhaust is is going to be the bottleneck in the overall system. You could have a 4" catback, but the flow can't get out any faster then the 2" s-pipe in front can empty into the catback. Now considering the amount of power we are working with on an N/A setup, the differene isn't going to be dramatic, but it will be there nonetheless.
As for the sound, I have no idea what the difference, if any, would be. When I did my exhaust, I did header to tip in one shot, so I don't have any experience with running different sized pieces at the same time...
[#] Feb 28, 2008 01:30pm
TOP: Home > Performance Mods > Exhaust > injen axelback help hp?
