| AEM DRY FLOW |
| ignition left on |
| Fuel Fillter??????? |
| throttle controller |
| wtb fuel controller |
carcandy
![]() Fuel / Ignition Controller (F/IC) The AEM F/IC is an economical solution for controlling fuel and ignition on vehicles that do not require stand-alone engine management, including variable cam timing engines like VTEC, VVTi and MiVEC. OVERVIEW The F/IC gives users with OBD-II vehicles and non-factory forced induction systems the ability to retard ignition and deliver accurate amounts of fuel without the need for outdated FMUs or “boost hiding” controllers. This system works parallel to the factory ECU preventing tuning limitations due to complex factory timing patterns and will not cause a check engine light (CEL). PRECISE FUEL DELIVERY The F/IC intercepts the signal to the stock injectors, allowing the user to modify pulse-width by +/-100%. The F/IC is the only piggy-back system that can decrease injector pulse-width, allowing the user to drive larger aftermarket injectors* while still maintaining proper air / fuel ratios. This powerful system can also tap into the factory injector signal and work independently to drive up to six (6) additional injectors. TIMING RETARD CONTROL The F/IC has the ability to retard timing by intercepting and delaying the outputs from the cam and crank position sensors to the engine- with no adverse affect on applications equipped with variable cam timing. The F/IC can retard timing from the factory system based on engine RPM and load inputs. SENSOR CALIBRATION & CONTROL The F/IC can also be used to recalibrate / clamp the MAF sensor, eliminating common problems with non-boosted factory MAFs. The on-board MAP sensor allows for proper fueling in boosted applications. http://www.carcandymotors...h=133&products_id=163 Contact for the lowered price. gregb@carcandymotorsports.com |
SuperXero
why do we always have to pm you for the price, why cant you just post it? |
carcandy
because some pricing I offer is below the MAP agreement and I cant post for everyone to see. I will get in trouble with manufacturers they have people monitoring sites. |
SuperXero
ah i see.. |
dsm3383
Do you offer a plug & play harness for the AEM FIC? Beer is proof that God loves us and wants us to be happy. -Ben Franklin |
carcandy
unfortunately AEM don't make PNP for it. But couple 3rd party company's have them. |
java09
AEM FIC is the best piggy back on the market right now! Dezod has harness for it as well as TurboToyotas. I think TurboToyotas is a tad bit cheaper. I got the harness from TurboToyotas for my e-manage and not one issue, PnP FTW! 2008 Turbo Scion tCizzle POWERED BY TURBOTOYOTAS! 310WHP, 272WTQ more to come_.. |
dsm3383
BUMP!!! This deal you cannot pass up!!!! Beer is proof that God loves us and wants us to be happy. -Ben Franklin |
carcandy
thanks guys. I only got few left so get yours now. |
I've been reading up on FI and a lot of boosted tC owners recommend the FIC, it's indeed a superior product ![]() ![]() ![]() The Thread Killah |
java09
^^concur, but lack of "intelligent" tuners here in hawaii for it, i opted for the e-manage.. its simply been around longer so more are fluent with it.. once someone here is good with it i will upgrade to the FIC if i dont already have a stand alone! 2008 Turbo Scion tCizzle POWERED BY TURBOTOYOTAS! 310WHP, 272WTQ more to come_.. |
dsm3383
I think a standalone is not worth it anymore. I was opting to get the AEM standalone ECU but since they released the FIC I have chosen otherwise. If your going to get rid of your "fly by wire" electronic throttle that is equipped to the tC and go back to the traditional mechanical throttle control system then a standalone will be needed. The FIC allows you to change from using a MAF sensor to a MAP sensor for tuning and control and that was the big factor in me leading to the standalone in the first place. Beer is proof that God loves us and wants us to be happy. -Ben Franklin |
JBoy510
so in terms of superiority, e-manage ultimate or aem? So what if my girlfriend drives a Supra, I'm more sexier than she is! =) ************* CHECK OUT MY GALLERY ************* http://www.clubsciontc.com/jboy510/gallery-8 |
carcandy
it depends what you looking for. |
