| need amp help!!! |
| Need help |
| Electrical help needed!!! |
| Need help picking a radio - specific needs |
| Need help fast!!! Please |
tc1stgen
So I was driving around today and my system was working fine. I went to the store and when I came out and started my car, my subs weren't on. The first thing I did is check to see if the power light was on, on the amp, which is was. I didn't think that it was a power problem, but I decided to check the fuse on the power cable and on the amp and they both are fine. So then I thought that maybe it was the remote wire. So I checked it at both ends and once again I was fine. I was so confused at this point that I decided to make sure the RCA's and the ground were ok which they were. So I have another amp and sub so I hooked those up and I have the same issue. Does anyone have any other suggestions? I should mention that my amp is hooked up to my factory headunit through a LOC and I checked those connections and they were fine?! Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
Triniosito
Might just be the connection to your subs cuz you said you checked every other connection....did you check dat????? ![]() |
tc1stgen
Yeah i checked that as well |
tc1stgen
bump Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
It sounds like the amp itself may be bad. Best way to check it would be to swap your amp into a buddy's whip and use all of his wires and subs, and see if the problem occurs. If so you've pinpointed the issue. I hadc a problem with my setup because best buy installers are retarded. After I took it back to them twice and to two other shops (who all told me my amp was bad) it turned out to just be a bad remote. Since you confirmed the remote wire, I'm leaning towards the amp. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
tc1stgen
The funny thing though is that I connected a different amp and sub to my car and it still wouldnt work?! |
If you tried another amp and sub (and know that they work) then it has to be a problem in the wiring somewhere. If you're getting power, then I would think that the rca's would be the problem. This kind of troubleshooting is trial and error, which is my least favorite. Did the 2nd amp you tried get power? Did you use the same speaker wire from the amp to the sub on both tries, cuz maybe that is the problem... ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
tc1stgen
Yeah both amps ge power but nothing comes out of the sub. I guess I will have to disconnect everything and reconnect to see. I honestly don't know how driving one second everything is fine, and then the next second nothing works. I hate troubleshooting, lol! Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
agent009_5
if the amps turn on then its either the loc or the rca's running from the loc |
^^Yeah. my next suggestion would be a bad LOC. Troubleshooting sucks! ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
tc1stgen
Well the guy that is sponsoring me (we have been talking about it in another thread) said he Weill take a look at it and test everything to see if they are bad so I will let you know how we make out. |
