Home > Visual / Audio Mods > Audio FAQ/Help > d3 (Avic D3 - How to change backgrounds)
bills22
Fitchburg
Massachusetts, US
how can i change the backround or put pic on it
--Edited title to be more specific @ 9:14 PM PST and moved to audio/faq by Andino
what
[#] Feb 13, 2008 12:14am
nick06tc
You have to put a picture on a CD/DVD. It has to be over I think its 15,000 bytes. Not sure the exact number.
Go into the system settings. Choose background and add the picture.
[#] Feb 13, 2008 08:05am
NewJersey
Kendall Park
will this work with any double din?
-kenwood---
[#] Feb 13, 2008 08:14am
VIP_tC08
Fort Lauderdale
what i did was save a few images into a folder named PICTURES then burned them onto a CD-RW CD using any burning software, i used the Roxio Program, but any will do...then just load your disk into your system, select the navigation menu, settings, change bacground image, then select the backgound section you want, then you will select import from disk..then all your saved images will be listed, you just then select the one that you like best for your background..if it helps any i have a gallery of all the images that i used, your free to use them..Good Luck
http://www.clubsciontc.com/tC_Whip08/gallery-251
'08 // Flint Mica // tC
[#] Feb 13, 2008 08:24am
TOP: Home > Visual / Audio Mods > Audio FAQ/Help > d3 (Avic D3 - How to change backgrounds)
