Home > Visual / Audio Mods > Wheels & Tires > Help_Wheel Buying
Help_Wheel Buying
prleet
http://www.tirerack.com/w...terNew=All&sort=Brand
Offset: 40mm Bolt Pattern: 5-100
Rec. Tire Size: 215/45-17
I know that 215/45/17 is the standard with 5-100 bolt pattern. However, I am confused whether the offset 40mm, would be fine. I don't know the standard factory wheel offset and would like to keep it that way. I have called the dealer and they don't know. I am thinking of calling toyota.
But anyhow, I have searched that for 2007 Scion TC at tirerack, so I am assuming it is good to go. Please help, further!
Thanks
[#] Feb 12, 2008 11:30am
Perry Hall
  • $upervillain
Good to go :mrgreen:
offset 35-45 is fine for that size.
[#] Feb 12, 2008 11:32am
prleet
Do you or anyone else know the factory wheel offset. I had customized cars before and I know that whatever I do, it will ruin the car as a whole just to look nice...so I am not trying to go away from their years of research on how to produce a good car.
Thanks again.
[#] Feb 12, 2008 11:39am
antiks
our stock rims r 45 offset.
[#] Feb 12, 2008 11:42am
prleet
Another question,
The tire pressure sensors, are they affected by moving from 45mm to 40mm offset.
[#] Feb 12, 2008 12:41pm
TOP: Home > Visual / Audio Mods > Wheels & Tires > Help_Wheel Buying
