| Sunroof problems... |
| header problem |
| ????Power wire Fuse HELP??? |
| Issue with wiring |
| Spark Plug Wires |
alstate
Reg'd: Feb 10, 2008 Window Washer |
i just put lambos on my car right and i had to extend the door wires. i matched all the colors right but my windows and door locks wont work...speakers are fine and side mirrors moves but cant roll the windows up and down nor can i lock the doors |
armygirl718
Reg'd: Dec 19, 2007
Just Keep Swimming! |
are you sure you didnt jam a wire somewhere in the door or short anything? ![]() http://www.itsmyscion.com/armygirl718 http://www.myspace.com/navsegdamaskva |
mrwilson99
Reg'd: Jun 30, 2008 Window Washer |
Prob blew fuses if you didn't pull the negative terminal out of your battery when disconnecting/cutting to relocate. Check your fuses. |
operatic
Did you solder or butt splice the wires that you needed to extend? Either way, check the connections that you may to see if they are good. Just double check everything and if you used butt splices go over them again. |
killer08tc
Reg'd: Jun 14, 2008 Detailer |
remove - bat terminal then hold window switches up and see how that works![]() 252 hp and 243 ft lbs (only 5 psi spring moves up to 6 psi) 14.3 @ 103 mph |
