| scion tc model car?? |
| Scion security system install question |
| New Styles for my Scion |
| One Winner: Scion |
| Scion Exposed in Houston |
scionteecee
I have the OEM Scion Security installed in my tC and I was wondering how you know it's functioning correctly. Is the red led supposed to blink when locked, or steady, or nothing at all? The other day when I locked my door there was no sign that the alarm was armed. Can someone elaborate how the alarm is supposed to operate? |
tc1stgen
Yes the red light should blink telling you that the vehicle is armed. Now I good way to test that it is working is by sitting in your car hit the button to arm the car. Once it is armed unlock the door with your hand and open it. The alarm should go off. If it doesn't, then either it is not working or it is in valet mode. Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
tCdreamer87
after u lock the doors the red light should go on, then give it a couple of seconds i think its like15 seconds or something and then it will start blinking. to test if it works you can tap on your driver glass with your key and it should give u a warning sound. also get inside of the car arm the car and then open the door it should go off rite away. all of the lights on the car should start going off and then if someone tries to hot wire it the car will just shut down completely. |
BatmansTC
most likely its in valet mode..cause once you lock the doors you should hear like 2 beeps (i believe), and thats what tells you its armed.. ![]() "She said its just a car...and i said your just a girl!! " |
scionteecee
The OEM alarm doesn't make sound when you lock or unlock. Also, if you lock the door and pull on the handle inside it unlocks the door. The red light doesn't turn on anymore after doors are locked. I don't remember if it ever did but I'm pretty sure it did. Cuz when I got the car they didn't have the alarm so I had to bring it in a diff time for them to install it. I just hope I didn't accidentally hit a wire when I installed my fog lights. |
chelex13
once u set the alarm the red light will stay on for 30 seconds. after the 30 seconds it will start blinking and thats when the alarm is on. |
scionteecee
wtf then my alarm is def jacked up |
light goes blinky blinky when armed. LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
unknownstyle
lmao i open the door when my alarm was armed and nothing happen o_O |
scionteecee
yes fixed it |
chelex13
what was wrong with it? |
tCdreamer87
make sure its good. their are roomers about the tC bein the new civic, but hopefully ours wont get stolen as much. |
henrygiang
does anyone know where i can get the scion security wiring diagram.. is it possible to disarm it? |
ScionMattTc
doesnt it come stock? |
tCdreamer87
after armin the car and ur still inside if u open the door the alarm should go off |
