| HELP! |
| help running wires from under hood to in cabin |
| ????Power wire Fuse HELP??? |
| Issue with wiring |
| Spark Plug Wires |
NewJersey
Im trying to wire my wiring harness into my kenwood ddx6017 .... the wires i have left on the back of the head unit are : -battery wire -external amp control -mute -power control wire -ignition wire and on separate plug on the back of the headunit: - Parking sensor wire -Battery wire - ground wire BUT on the wiring harness i only have A 12 volt battery and a 12 volt ignition and an illumination... im trying to override the parking brake but i dont know which ones to wire into the harness ( i know i have to ground the parking brake wire with a switch of some sort but can i ground all of the ground wires left into the main chasis ground or what... |
NewJersey
like tie wires together on the headunit and then wire more than 1 wire into a harness |
