| What mm diameter is TRD Rear Sway Bar??? |
| sway bars |
| I NEED hotchkis sway bar (rear) bushings |
| Will these rims fit? |
| Will these Rims fit |
flintmica08
Here is a link to a set of Hotchkis Sway bars. Only thing I'm worried about is it says they are for the 05'. Anyone one know if they will fit an 08?? http://www.killertc.com/p...05&cat=329&page=1 |
they should fit. the only thing you can't use from previous models are the intakes ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
flintmica08
thats good news. any idea how easy or hard they are to install?? I'm thinking maybe a couple hours if I take my time. |
Front sway bar requires removal of S-pipe and tires. May take a bit while fishing the bar out from the suspension. The rear is cake. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
RoulettetC
Hotchkis is the way to go! ![]() -Thanks for the sig Aciidsneaker |
flintmica08
yeah I figured the back would be easy. I wasn't too sure about the front though. settle a debate for me I'm having with a buddy. Which would improve your "performance" (as far as corners and handling) more.... a set of sweet sticky tires or a set of good sway bars? |
you need to drop the engine cradle to get to the front sway bar... yea... but honestly... i'd go for sway bars over tires... however having both would obviously be best... along with a lower suspension to lower the center of gravity.. LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
rrimportracer
its possible to do the front without lowering the cradle... but its hard and like web said it requires a lot of fishing. Your best bet when you do the front is to lower the cross member but that requires a lot of work and involves a lot of components ![]() myspace.com/asphalt_photos check us out!!! |
