| What would YOU do with $1800 towards your tC |
| What else do I need? |
| How would i ship out an engine? |
| some mods i havent showed off yet =P |
| What would happen if..... |
tc1stgen
Ok so right now I have a Greddy strut tie bar, Tein S-techs, and an Ingalls rear shock tower brace. I would like to improve the handling as much as I can. Would I be better off with a rear sway bar or a rear tie bar and what exactly is the difference? Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
cookiemonster
A sway bar is an is a part of the cars suspension. It connects opposite (left/right) wheels together through short lever arms linked by a torsion spring. A sway bar increases the suspension's roll stiffness—its resistance to roll in turns, independent of its spring rate in the vertical direction. As for the Tie bar I am still look for an answer but there are a lot of knowledgeable and experienced ppl on the site. Help me out here guys^_^ what are the mod for DD, drag, drift? cookie monster ![]() If two men agree on the same thing then one of them is no longer needed. ^_^ |
tc1stgen
Well it is a DD right now. I do drag once in a while, obviously can't drift because it is FWD, but I do autocross and that is why the suspension upgrades are important to me. I know what they do, but I am not sure if a sway and a bar do the same thing and if so which would be better. Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
Triniosito
Sway bar and tie bar pretty much do the same thing and as for autosross you might wanna look into changing your endlinks also ![]() |
Sway bar prevents rolling from side to side and Strut braces prevent chassis torque on turns and acceleration. Sways prevent Left to Right rolling onto outer edges of tires causing loss in traction. Strut braces prevent the frame from corkscrewing itself upon given forces (acceleration...mainly from RWD vehicles..or high speed turns). Best example of torquing off the line: (look at the difference in height of his front wheels...front passenger side is lower than front driver's due to corkscrew effect translated to the frame by the grip of the tires) ![]() Example of how sway bars work: (tires are flat, unlike in torquing, but body of car rolls from side to side) ![]() Hope this helps. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
tc1stgen
Ok well I have an opportunity to get a TRD rear sway from a good friend for $85 dollars. Now even though this is cheap, I am going for performance, so is the TRD sway a good buy or would I be better off with a different one? Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
Hotchkis front and rear FTW! ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
tc1stgen
So would you consider TRD rear sway to be a waste of money? I agree that TRD is overpriced and I do not have any TRD products on my car because I believe aftermarket is better than anything designed by the factory, however this price is very tempting. Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
SoFloTC
id say why not? go for it. |
greddytc05
just get the hotchkis front and rear. that way you will take away body roll from the entire car. and since you autocross that is what you want. Car is being put on hold until further notice. Work will continue pending on if i get the new toy i want or not. I will keep you all posted. UPDATE ON THE TUNE. It went ok but a few little issues that are causing my performance to be less than expected have shown themselves. Now I have to resolve them when I get the chance and it will be back to PTuning for the finishing touches. "warning: friends dont let friends learn to drive from watching the fast and furious." me BOUGHT,BUILT,PAYED FOR BY ME ![]() ![]() '05 BSP TC 5 Speed 255.13hp 286.34tq. 13.708@101.07mph. 60'-2.114 on street tires and stock clutch. More to come. |
Hotchkis is good, but it's overkill for a DD... I've got a TRD rear sway and it's perfect for normal and aggressive street driving. 85 bucks is a steal, go for it. edit go for the rear sway FTW!! |
Imagin
Hotchis is a bit extreme for a DD. If your a hardcore auto-x then id say the tradeoff is worth it. Passed that just the TRD sway will do you just fine |
