Home > Performance Mods > Engine Mods > Decided to go Turbo.
Pages: << 1 2 3 4 5 6 7 8 9 >>
emerilnut
Georgia, US
RusWolf wrote:
Wow guys great answers, I appreciate your all inputs. Whats the difference between BOV and Bypass valve ?
BOV's usually vent the air to atmosphere.
Bypass or diverter valves redirect air upstream back into the intake plenum.
Bypass valves are better for cars with AFM's like the Scion, because the AFM has already measured the amount of air taken in. BOV's that vent to atmosphere will lose that metered air and your mixtures will get screwy...
If you go with the right ECU, then it will use a MAP sensor in the intake manifold and you can do away with your AFM. Then it won't matter if you use a BOV, because the air isn't metered until it's enetered the intake manifold. At that point, it won't matter what happened in the intake plenum.
2008 Scion tC - completely stock for now...
1995 Mazda Miata - supercharged, MegaSquirted, soon to be a T3 Turbo...
1990 Mazda Miata - SCCA Club Racecar, ITA Class
"Auto racing's boring except when a car is going at least 172 mph upside down."
"I know that son-of-a-bitch is cheatin! Cuz I'm cheatin' and he beat me!"
[#] Jan 07, 2008 10:59pm
RusWolf
Yonkers
sounds good I actually want to be at 300 WHP , not more then 320 at 9 psi and 240-250 at 5 psi. The reason is because i want to keep the car for a looooong time as a wuick daily driver and around 2011 get a new Camaro SS for my weekend fun pretty much i'm keeping tC to keep the miles low on camaro.
[#] Jan 07, 2008 11:01pm
emerilnut
Georgia, US
RusWolf wrote:
Hmm and i actually thought that to run 2 different psi levels i will need 2 maps. am i wring ? i 'm trying to run 5 psi daily and like 9psi when at the track or racing someone. I'm sure they will be surprised.
You can do that, but you're going to need electronic boost control.
To change boost control with a manual boost controller will mean changing the spring every time you wanna change boost levels.
Make sure the ECU you choose can support EBC.
Actually, these are things I need to investigate as well for my car. My plan was to have one fuel/timing MAP that's tuned for boost all the way up to 20 lbs. Then I adjust the spring in the manual boost controller to give me like 12 lbs for everyday driving, and then adjust for 18 lbs for ramp runs or fun runs or something... Either way, the ECU will handle the ratios whatever boost level it sees.
[#] Jan 07, 2008 11:03pm
java09
Honolulu
Hawaii, US
youll be fine with what your goals are. just read up a little more on turbo charger and get farmiliar with how it works and what not!
2008 Turbo Scion tCizzle
POWERED BY TURBOTOYOTAS!
310WHP, 272WTQ
more to come_..
[#] Jan 07, 2008 11:04pm
emerilnut
Georgia, US
I highly recommend reading this book...
[#] Jan 07, 2008 11:07pm
RusWolf
Yonkers
which a pillar gauge pod do you recommend ?
[#] Jan 07, 2008 11:08pm
java09
Honolulu
Hawaii, US
i am gonna say no.... you dont need to change the spring everytime you wanna change boost levels?!?! most manual boost controlers are like knobs, one full tun to the right equals one full psi increase, and one full turn to the left equals one less psi.
310WHP, 272WTQ
more to come_..
[#] Jan 07, 2008 11:13pm
java09
Honolulu
Hawaii, US
i didnt go with a a pilar pod peep my profile and check out my gallery and you can see what i did. im at work and cant post pics!
310WHP, 272WTQ
more to come_..
[#] Jan 07, 2008 11:14pm
RusWolf
Yonkers
Ohh yeah guys i'm definetly learnign and reading, thats the reason why i crated a thread to learn and as you can see i'm 6 month away from my set up, but i decided to start ahead figured it would be wiser and easier on my wallet.
RusWolf
Yonkers
ohh yeah you did that in the center, then you probably getting ATI center gauge. I'm considering that one as well.
[#] Jan 07, 2008 11:15pm
emerilnut
Georgia, US
Yeah, woops. I caught myself at the end of my post. I don't know what I was thinking... adjustable screw. duh!!!
[#] Jan 07, 2008 11:17pm
java09
Honolulu
Hawaii, US
haha no worries man if you saw the page before this i caught cookie monster with his hand in the cookie jar too! haha just want to make sure this guy gets all the good info!
310WHP, 272WTQ
more to come_..
[#] Jan 07, 2008 11:19pm
RusWolf
Yonkers
Ohh yeah , thats what i want straight up info lol..
btw guys you can call me Yev for short, whats your names fellas ?
Glow shift are those guys any good? their pod are pretty cheap, or should i order autometer that dezod offers ?
[#] Jan 07, 2008 11:22pm
java09
Honolulu
Hawaii, US
make sure you get a good name air fuel gauge like the aem uego wideband controller.. and i personally havent dealt with the glow shift gauges but ive heard they are not as acurate as others. remember you get what you pay for. dont cheap out on the monitoring system (the gauges) of you major investment(the turbo kit)!
310WHP, 272WTQ
more to come_..
[#] Jan 07, 2008 11:26pm
java09
Honolulu
Hawaii, US
my name is brandon btw haha but eveyone calls me java.
310WHP, 272WTQ
more to come_..
[#] Jan 07, 2008 11:27pm
RusWolf
Yonkers
Well i'm definetly not gaoing with their gauges, iw as think about their gauge pod, if its actualy 100% fit or not. I'll just probably go with autometer.
[#] Jan 07, 2008 11:28pm
RusWolf
Yonkers
well i'm gonna call you Brandon, to separate myself from everyone, lol
[#] Jan 07, 2008 11:29pm
emerilnut
Georgia, US
I'm Stan
[#] Jan 07, 2008 11:33pm
java09
Honolulu
Hawaii, US
roger that. haha yeah ive actually seen someone with the glow shift pod and it had some fitment issues and had to be shaven down a bit on the ends but other than that it looked ok. i wanted a more custom look. i heart my shit! haha
310WHP, 272WTQ
more to come_..
[#] Jan 07, 2008 11:34pm
RusWolf
Yonkers
custom is always good
hey whats up Stan noce to meet you guys, lol
I had a roommate in college his name was Stan, he never tried alcohol untill he lived with me, after 1.5 shots of vodka ( 1 shot of cheap american and 05 shots of Stoli) he was drunk and started to vacuum the room, i was tired of laughing and just walked out, lol.
P.S. Ohh and his hair grew straight up ! No joke, he was pre-med major and i think all that chemistry got him !
[#] Jan 07, 2008 11:38pm
RusWolf
Yonkers
Brandon, what number u putting down do you know yet ?
[#] Jan 07, 2008 11:45pm
SoFloTC
Boca Raton
lets say i ran the basik kit on an automatic with the emanage and a nice tune what numbers could i look at pushing around 12 psi during races?
[#] Jan 07, 2008 11:49pm
java09
Honolulu
Hawaii, US
its not so much about number is your case because you have an automatic. for you i wouldnt exceed 290 horespower.. i think thats more than enough on the auto and thats is kinda what you want to look at really.
310WHP, 272WTQ
more to come_..
[#] Jan 08, 2008 12:02am
RusWolf
Yonkers
automatic , hmm honestky i'm not sure and i dont want to lead you in the wrong directions , but i think you will be very close to around 260-270 myabe more. Better talk to Todd from whyindustries.com he actually the one who makes this kit. Very nice guy too. He said that at around 9-10 psi with MT the kit will perform very close to 300 whp.
I'm also going to run Dezod 2.5 inch turbo back exhaust which adds like 20-30 whp.
java09
Honolulu
Hawaii, US
im putting down anywhere from 320-340.. closer to 340 and will confirm that soon with a actual dyno.. as of right now those numbers are based on others who have dynoed and im bouncing numbers off that!
310WHP, 272WTQ
more to come_..
[#] Jan 08, 2008 12:04am
TOP: Home > Performance Mods > Engine Mods > Decided to go Turbo.
