Home > Performance Mods > Intakes > Longer start of ignition after intake
scionteecee
Fairfax
After u guys installed a intake did u notice it takes longer to start the ignition. with stock intake it took about 1 second but with the injen it takes about 2-3 seconds. this is normal right?
[#] Jan 05, 2008 10:56am
slvrscion06
Houston
i didnt notice
myspace.com/adriancontreras
[#] Jan 05, 2008 11:05am
psiewert
Gurnee
Illinois, US
if it took 2 seconds to start your car with the stock intake, you already had a problem. Your engine should only really take about a second of grind time before it starts.
[#] Jan 05, 2008 11:34am
RoulettetC
Frederick
Mine start right up with the injen hardly a delay at all, if any.
[#] Jan 05, 2008 02:17pm
JenWest
YES!!! omg i have been sain this for two months and my bf thinks im crazy...sometimes my car wont even start it will take about 3 times to get it going
[#] Jan 05, 2008 02:18pm
SoFloTC
Boca Raton
if ur car doesnt start then theres something wrong its not the intake
[#] Jan 05, 2008 02:22pm
JenWest
there is just somethin wrong wit the car ugh i hate it it sounds like its fallin apart
[#] Jan 05, 2008 02:24pm
scionteecee
Fairfax
well i kinda exagerated. there is only a slight delay. but a noticeable delay from stock. is this normal?
[#] Jan 05, 2008 02:46pm
06tCdude
San Antonio
make sure the mass air flow sensor isnt loose. even try sprayin the connector with wd-40. i know at work when i have a MAF off and start a car it takes a bit to start, then it shuts off.
custom doesnt come from mommy and daddy
I DONT street race, I QUICKLY accelerate against other cars
[#] Jan 05, 2008 02:52pm
psiewert
Gurnee
Illinois, US
DO NOT USE WD-40!! You'll run the risk of dissolving the diaphragm inside the MAF. Use intake cleaner or maf cleaner. Also, make sure you didnt forget to disconnect all of the vacuum hoses.
[#] Jan 05, 2008 05:23pm
06tCdude
San Antonio
not on the MAF itself. just on the connector
[#] Jan 05, 2008 05:25pm
youngflyer
Germantown
do any of you feed gas in when starting?
ThE JeWiSh PiMp
[#] Jan 05, 2008 05:47pm
scionteecee
Fairfax
no y
[#] Jan 05, 2008 06:29pm
youngflyer
Germantown
just wondering because that can cause delay
ThE JeWiSh PiMp
[#] Jan 05, 2008 06:31pm
psiewert
Gurnee
Illinois, US
it also flood your engine
[#] Jan 05, 2008 08:47pm
TOP: Home > Performance Mods > Intakes > Longer start of ignition after intake
