| Scion tC In Burger King Commercial |
| Wiper blade sizes for the tC |
| 09 Scion tC owner now!! :) |
| Scion tC Grilles |
| Scion tC Model Cars |
The information in this thread will be updated as more information is available, but in the meantime this should be helpful to those that need a quick reference. First up.... bulbs for the low beams 9006---for normal driving---05-07 low beams and OEM Foglight ![]() an easy way to point out the 9006 is the thin bit of metal coating on the tip... it should also say "9006" there are only two metal prongs. High Beams----for spotting those deer----9005 ![]() 9005 High beam bulbs burn brighter and usually do not contain the metal at the tip of the bulb. It also has two metal prongs, but will not fit a 9006 female plug unless the plastic is modified. Projector Headlamps (2008 + tC + xB----H11) ![]() New tC's and xB's which feature projector housing and lenses use an H11 size bulb, this size will also need to be specified when ordering HID for your newer model car. Other aftermarket headlamp housing my use a different size H bulb, be sure and check. The OEM projector from Scion uses an H11 OEM Fog Lights for 2008 will use H11 7440 Turn Blinker Bulb-----use your turn signals! ![]() The bulb can be replaced with other colors but it's illegal in all 50 states to use a non amber bulb (when illuminated) Use amber 7443 Brake Bulb ![]() Notice the difference from the turn signal. These bulbs have two filaments in them. 921---Your reverse lights ![]() reverse lights... nuff said. 194/168----Most of the bulbs in the interior, parking, domes, side markers and license plate ![]() They are called 194 or 168 because they are both the same thing. These tiny bulbs are polarized (like most of the bulbs above) meaning you must use the correct + or - or it will not light up. These are also the parking lights used for the 2008 Scion tC. Interior Rear Dome----3175 (10mm x 31mm)--called a Festoon type Trunk/Luggage Light---3022 (08mm x 28 mm) Festoon ![]() the easiest bulb to replace, just snap into place. Center Cubby Hole---74 ![]() it's a smaller bulb, it comes in normal incandescent or LED Speedo gauge/HVAC LED/steering wheel controls/Window switches---PLCC LEDS ![]() tiny little LEDS that must be soldered into place OEM Radio----0603 /window switches LEDs: 1206 ![]() for OEM Radio/Window Switches Mirror Signals 5mm SuperFlux ![]() these LEDs must be soldered into place to replace the OEM LED. special thanks to: for providing additional bulb information last updated---05/16/2008---7:52 central----added 7443 brake bulb |
07TouringCoupe
Man you beat me to it. Nice write up A car is only as good as it's driver. |
08FastTC
H11 For lowbeams 2008 tc and xb |
^thanks, I'm going to add that |
Cubby LED: 74 Wedge bulb Auto Shifter LED: 74 Wedge Bulb [img]http://home.comcast.net/~velocityusa/74.jpg[/img] (#74 LED bulb) Rear Dome LED: 3022 ![]() For those DIY LED swappers Mirror Signal LEDs: 5mm Superflux ![]() Speedo gauge/HVAC LED/steering wheel controls/Window switches: PLCC LEDs ![]() OEM Radio----0603 /window switches LEDs: 1206 ![]() Size Comparison between PLCC and 0603: ![]() last updated: 01/25/08----08:50 central ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
Awesomeness! I'll add this with pics later too! |
^^ yah sorry i was going to add pics but i'm at work and my boss just dropped off a bunch of things for me to do lol. if i have a chance i'll edit them in for you edit: eh i just did them for you Orin lol ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
VIP_tC08
Great write up Orin, this will definetely be one of the most usefull treads ever created, i have lost count as to how many members i have seen asked what bulb for this, what bulb for that..this should definetely be stickied ![]() '08 // Flint Mica // tC |
VIP_tC08
you might want to add that the steering wheel radio controls and the door lock lights also take PLCC -2 LEDs ![]() '08 // Flint Mica // tC |
^^ oh yah good call. window leds are 0603 though but the plcc-2 will fit lol ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
thank you very much, I've added the updated information! |
BatmansTC
you guys should put the brightest bulbs that there are for each set. And where everyone should buy them,superbrightleds,onzium(spelled it wrong I think,sorry)etc. |
On3Sh0tBlaz3
what about the factory oem foglights? do you have information on those bulbs by any chance? thanks in advance ![]() |
Fliphm00b
Your factory bulb size for your foglights is H3s ![]() |
On3Sh0tBlaz3
thanks bro! ![]() |
antiks
the low beam i saw fasttc post its h11 for 08' is it the same for 07? |
You bring up a good point... on 07 and prior the factory OEM fogs are 9006. On the 2008 + it is most likely an H11. If anyone can confirm this, I'll update the information |
antiks
so for the 07 and prior its defintly 9006 for lows and oem fogs, HB4 Halogens. |
MUStC
There is this link I posted last year thats been stickied which doesn't have pics but is great for all your tC info: http://home.cfl.rr.com/icdedppl/faq.html#c The Scion tC FAQ Site![]() ![]() |
^ That is some useful information, but it's not updated for 2008 Projectors. |
i think the fogs remained 9006. i'll look it up ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
antiks
yes oem fogs r 9006 |
Kurisutaira
yea i needed the fog lights too i ran a cat over last night on my way home it knocked my entire bottom grill out of wack and blew on of my fog lights ![]() "This is what happens when an unstoppable force meets an unmovable object" |
tc1stgen
You can also go to sylvania.com to get bulb sizes on an car. Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen http://www.myspace.com/tc1stgen http://www.tunerfriends.c...mber.php?u=13341&8685 http://www.cardomain.com/ride/3084016 "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
the door and window switches are 1206. 0603s only apply to the radio. LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
