Home > Performance Mods > Transmission / Drivetrain > Will This Shifter Fit My 08?
sevnofspades
Plantsville
Connecticut, US
seems like a real good deal and it should fit correct?
http://www.hopupracing.com/merashshsctc.html
Thanks!
[#] Jan 01, 2008 06:47pm
07blackedouttc
yes it will i have this same one
NEED INTERIOR PAINTED? BADGELESS GARNISH? PM ME FOR INFO
WANTED: HEADLIGHT LENSE OR CHEAP HEADLIGHTS
FIRST CSM WITH NIA KIT
[#] Jan 01, 2008 06:48pm
sevnofspades
Plantsville
Connecticut, US
do you like it? and how hard was the install?
Thanks
[#] Jan 01, 2008 06:50pm
07blackedouttc
i like it, it will take a lil while if you know what you are doing but you must have a drill or dremel to get a washer off if you search the forums for short shifter install youll see what i mean, i did mine in 30 min
[#] Jan 01, 2008 06:52pm
MrScion07
Rochester
Massachusetts, US
i used a hack saw to get the washers and then a flat head to brake the washers
[#] Jan 01, 2008 06:55pm
sevnofspades
Plantsville
Connecticut, US
wonderful...drills and hacksaws...should be a 2-3 beer job
[#] Jan 01, 2008 06:56pm
07blackedouttc
i just drilled it with a step up bit and it came right off
[#] Jan 01, 2008 07:00pm
sevnofspades
Plantsville
Connecticut, US
got a pic of the shift knob they send with it?
Thanks
[#] Jan 01, 2008 07:01pm
MrScion07
Rochester
Massachusetts, US
DIY for shifter install on tC
http://www.scionlife.com/forums/viewtopic.php?t=36452
DIY for shifter install on xA and this one shows the washer u will need to cut
http://www.scionlife.com/forums/viewtopic.php?t=28859
[#] Jan 01, 2008 07:03pm
07blackedouttc
here it is i took it off because i like the feel of the stock one better
[#] Jan 01, 2008 07:04pm
Aviator213
Hagerstown
lol
[#] Jan 01, 2008 07:47pm
warlock_bcrich
Norfolk
changing your shifter isn't a problem if you can get the washer off. i ended up using a dremel and it came right off afterwards. this is after i fought the damn thing for about an hour without the dremel. go to walmart and get you a cheap dremel and just cut it off. it should have a replacement washer in the pack.
[#] Jan 01, 2008 08:12pm
TOP: Home > Performance Mods > Transmission / Drivetrain > Will This Shifter Fit My 08?
