| How much Suede is needed... |
| Viper 3903V OEM Alarm |
| 5701 viper |
| request: take off stock antenna |
| How bout them Cowgirls? |
legaleye3000
I just got my windshield tinted and they had to remove the antenna for my Viper system which was glued to the bottom-left of the windshield... How do I get it back on the window? Thanks! |
you'll either have to just glue it back over the tint, or actually cut a square out of the tint and glue it back on the windshield directly. Isn't there any place else you could put it? ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
BatmansTC
couldn't you just glue it on the dashboard or right behind the rear view mirror?? Maybe you can use 3m tape instead! |
legaleye3000
That's where the installers put it... The wires are in the bottom left of the windshielf so if it goes anywhere else, there will be wires everywhere... But what type of glue do I get? What's wrong w/ the bottom left? No one can see it... |
07blackedouttc
use 3m double sided tape, glue would be a bad idea NEED INTERIOR PAINTED? BADGELESS GARNISH? PM ME FOR INFO WANTED: HEADLIGHT LENSE OR CHEAP HEADLIGHTS FIRST CSM WITH NIA KIT |
yeah... even double-sided tape could be bad as you can ruin your tint.. much worse if glued.. uhmm.. what state are you in that would even remotely allow a windshield to be tinted? even in most states having your front windows tinted would be pushing it.. can't imagine a windshield... good luck with that. LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
