| Led replacment parking lights |
| Blue parking lights with regular headlights |
| Parking bulb fell in bulb housing HELP!!! |
| Request: Parking Bulb Removal |
NewJersey
i tried to get them out yesturday and i cant get them out, i was pulling so hard, is there an easier way to do it, cuz i slipped and hit my hand so hard so i gave up. |
N8thegreat22
I have bad news for you... there is no easy way to get those dang things out! The only way to do it is with your hands. You colud try to use pliers or something like that but then you run the chance of breaking the plastic part. I would suggest using something soft like a rag if your going to do that, or just keep working away at it. Once you get it loose however it comes out very easy! Good Luck |
gicode0823
easy way -> take everything apart and take the headlight off ! lol i had a problem with it too but now somehow i can take it out easily lol ![]() member of TEAM SCION EYED |
MrScion07
i had a problem with it but eventualy got it seemed like one side came out easyer then the other idk. Wiggle them around as u twist ![]() |
Imagin
Its very easy. On the pass side, pull back the washer fluid tube a bit, grab hold of the parking light back, and TURN TOWARDS THE ENGINE. It comes right out easily. Driver side turn towards engine and comes out easy. |
08FastTC
You just have to wiggle it as your trying to twist it off. It should work. |
well.. if you were just pulling.. that'd be the problem... lefty loosey. LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
NewJersey
i tried everything and cut my fingers up no matter wut i did haha, wen i get home tonight ill give it another go with like rubber dishwashing gloves on |
sicktc06
Yea it's a pain in the butt and a very tight place to try and maneuver your hands, but eventually, you'll get it. ![]() A Small Tweak, Makes a Big Difference. Now here! http://i97.photobucket.co...6/Scion%20tC/DSC_0158.jpg Don't follow me... I run into walls. http://www.myspace.com/sicktc06 |
Imagin
Its not that hard at all.... like i said drivers side, is easy. Turn them towards the engine, and they come right out... the other side just pull back on the washer fill tube. |
