Home > Performance Mods > Intakes > HELP fujita intake
HELP fujita intake
jyhuh
Raleigh
North Carolina, US
my fujita intake is coming in afew hours. anything i need to know before i install it? never done it before. i dont think ive seen a diy or anything.
[#] Nov 18, 2007 07:44pm
Rockville
  • The Guru
I'd be suprised if it doesn't come with instructions. Either way, this could be helpful:
http://www.scionlife.com/forums/viewtopic.php?t=123625
Its by far one of the greatest reads on there, hahaha. When you get your intake, dont hesitate to come online and ask some specific questions
[#] Nov 18, 2007 07:51pm
08Crimson
Bloomington
Indiana, US
There is no need to remove your wheel, just turn it all the way to the left and you'll have enough room to remove the blots, clips, and screws in the inner fender. Also, the instructions will probably tell you to remove your front bumper, no need; just unbolt the drivers side and remove those have of the clips. Your only going to be in the bumper a little bit and taking it off is just more time needed to install. You don't even need to take the inner fender out, just let it fall down on its own or pull it down a little out of the way.
[#] Nov 18, 2007 08:02pm
jyhuh
Raleigh
North Carolina, US
well, my tc is lowered 2.4 inches in the front, so i probably will need to take off the wheel, i hope not tho
[#] Nov 18, 2007 08:54pm
Rockville
  • The Guru
^ That would be my suggestion. It takes like what, 2 mins to get the wheel off? Haha.
You just get more room to work with
[#] Nov 18, 2007 09:00pm
07TouringCoupe
Baltimore
You also gotta remember to reset the ecu so ur CEL wont come on
[#] Nov 18, 2007 09:10pm
SoFloTC
Boca Raton
my CEL never came on and i never reset my ecu?
[#] Nov 18, 2007 09:18pm
jyhuh
Raleigh
North Carolina, US
whats up with removing the headlight ground bolts?
[#] Nov 18, 2007 09:24pm
youngflyer
Germantown
thats easy...the hole for it is obvious...like the only one the screw will fit into!
ThE JeWiSh PiMp
[#] Nov 18, 2007 10:20pm
sevnofspades
Plantsville
Connecticut, US
same here...no cel, but should I reset my ecu anyhow?
Thanks
[#] Jan 10, 2008 08:08am
antiks
u should so that your ecu can recalculate how much air goes in.
[#] Jan 10, 2008 09:26am
sevnofspades
Plantsville
Connecticut, US
but doesn't the ecu calculate airflow in real time? BY that I mean constantly measure airflow and calibrate itself accordingly....
Thanks
[#] Jan 10, 2008 05:56pm
TOP: Home > Performance Mods > Intakes > HELP fujita intake
