Home > Visual / Audio Mods > Detailing > removing bugs from hood/bumper
Pages: 1 2 >>
SiL3ntKiLL
Reg'd: Oct 22, 2007
Detailer
ok so from my drive from alabama, i decided to wash my car. i cant for the life of me remove all the bug splatter. i used meguiers gold class shampoo car wash and most of it came off but the rest is still on there. then i tried quick detailer and still it didnt come off. any ideas?
[#] Nov 12, 2007 02:33pm
Reg'd: Oct 21, 2005
$upervillain
Try a clay bar. They can get just about anything off of your car. Also, if you fill your wash bucket with hot water from inside, I've noticed that helps to loosen up the bug remains. If that doesn't work, just repaint the car
[#] Nov 12, 2007 03:38pm
SiL3ntKiLL
Reg'd: Oct 22, 2007
Detailer
yeah ill try the clay bar, and ill try using hot water
[#] Nov 12, 2007 04:36pm
Reg'd: Aug 16, 2007
This is the best stuff on the planet
Gold Class™ Bug & Tar Remover
Bug splatter and road tar are highly adhesive and when left in place they will bond to your paint, potentially causing etching or staining. Gold Class™ Bug & Tar Remover is specifically designed to remove these extra tough substances before they mar your finish. For safe and effective removal of contaminants, we suggest using a high quality 100% cotton towel like our Ultra Plush Super Terry for agitation and final wipe off.
CLICK HERE TO DONATE & HELP MAKE THIS WONDERFUL SITE OF OURS BETTER!
[#] Nov 12, 2007 04:42pm
OldJersey
Reg'd: Jan 09, 2007
Vehicle Designer
yea any big and tar remover, some hard scrubbing and your fingernail
[#] Nov 12, 2007 09:39pm
Reg'd: Aug 16, 2007
I wouldnt recommend using a fingernail. Use a microfiber towel.
[#] Nov 12, 2007 11:47pm
Reg'd: Oct 21, 2005
$upervillain
Fingernail = bad
[#] Nov 13, 2007 08:44am
Racr350
Reg'd: May 18, 2007
Chief Mechanic
Try RainX Bug&Tar Remover...Works Great...Its like they melt right off...
-BearZ Rules!
[#] Nov 13, 2007 10:01am
Reg'd: Aug 16, 2007
FrAnkRYzzO wrote:
Fingernail = bad
Yea, its bad for the paint. & ur nail ..lol
[#] Nov 13, 2007 01:49pm
dangerkitty22
Reg'd: Apr 17, 2008
Window Washer
from a seperate thread... the magic eraser definately works really well too! ;-)
[#] May 30, 2008 11:10pm
CadenceScion
Reg'd: May 27, 2008
Oil Changer
I have had real good luck w/ Rain-X car care products. I have also used a clay bar system to remove bugs, and also WD-40 works really well too. I also will use Fantastic occasionally when I am in a fix. Be sure when you wash your car, use a quality car soap, minus the harmfull chemicals found in other soaps. DO NOT use laundry soap to wash your car, which will ruin the paint and leave lots of streaks behind. Plus it is not made to wash paint. The chemicals in laundry soap will make your paint look dull and not shiny, and can remove the polish and wax you have applied to your paint prior. I like to use a few drops of Dawn dish soap which is quite mild, and good quality car soap. Dawn I have found will help break up dirt, grime, bugs, and other junk in the paint. Plus washing your car w/ warm-hot water helps a ton too.
[#] Jul 01, 2008 08:08pm
Reg'd: Feb 14, 2007
The Guru
Was just about to say Magic Eraser!
[#] Jul 01, 2008 09:30pm
bonaviche
Reg'd: Apr 07, 2008
Chief Mechanic
im onli on this thread cuz im also curious on how to get dem off...lol, and havn a white tc, its very hard to notice da blood splattered all over my bumper...haha, NOT!!! im gonna try some of thes products see which one i like....
[#] Jul 01, 2008 09:58pm
beyond305
Reg'd: Jun 03, 2008
Oil Changer
down here in FL they have those do it your self car washes that you just pull into and you can use the foaming brush, high pressure hose, blower, and some kind of conditioner...theyve got a option for bug removal at some of the places. I usually spray the common areas with theyre stuff and let it soak in while i begin to wash the rest of the car. Then by the time I go to rinse it off it just comes off with ease. Every year we get a BIG problem from these love bugs and it last about a month. Real hassle to clean but this does the job.
[#] Jul 04, 2008 04:04am
killer08tc
Reg'd: Jun 14, 2008
Detailer
magic eraser is amazing
252 hp and 243 ft lbs (only 5 psi spring moves up to 6 psi)
14.3 @ 103 mph
[#] Jul 05, 2008 08:20am
breakout831
Reg'd: Mar 11, 2008
Chief Mechanic
magic eraser IS amazing. Just wet a portion of it down before using it and don't push to hard or go too fast because the heat from the friction will leave a mark. I had this happen on my mustang. Luckily it was on the front bumper in a spot where no one looks and it wasn't that big.
[#] Jul 05, 2008 09:53am
Reg'd: Dec 08, 2005
I've experimented with a lot of different methods of removing bug/guts from the bumper, especially after they've been baking in the sun and I've come down to a few favorite methods.
1. warm soapy bucket/ w bug scrubbing sponge / finish with clay bar
2. Mr. Clean Magic Eraser --- by far the easiest method, but I always wonder if a microscopic layer of my paint is coming off with those bugs. Works fantastic and I've only used it twice. Best results.
3. High pressure wash + some scrubbing + clay bar.
[#] Jul 05, 2008 10:02am
epidemic
Reg'd: Dec 15, 2007
Chief Mechanic
really, im gonna try this out this weekend
[#] Jul 28, 2008 07:04pm
Kurisutaira
Reg'd: Aug 04, 2007
paint thinner works really good too
[#] Jul 28, 2008 07:30pm
epidemic
Reg'd: Dec 15, 2007
Chief Mechanic
haha i just read some of the other post lol ummmmmmm idk about that fingernail thing
[#] Jul 28, 2008 07:32pm
RoCkStArr
Reg'd: May 10, 2008
Oil Changer
take a magnifying glass and burn those fuckers off! lol i am not responsible for any car damage... do at ur own risk! i had da same problem wen i drove 2 canada... i jus had 2 get use 2 dem so der like part of my ride now... i think ive named dem all already lol
i fractured my rib back in march in da back of da ambulance... now i fractured my spine carrying a patient out of his house! wats wrong wit me?!!?!? and dont say im fragile!
[#] Jul 28, 2008 07:37pm
VIP_tC08
Reg'd: Dec 02, 2007
I just purchased the Turtle Wax Bug & Tar Remover..its really good
Turtle Wax® Bug & Tar Remover is an innovative product formulation that removes bugs, tar, tree sap, and road grime from your car's finish and restores a deep gloss shine. This is a gel formula that clings to vertical surfaces, thus allowing it to penatrate for better cleaning performance. Not only will it clean, this product also leaves a shiny protective wax barrier that helps prevent future bugs and grime from sticking to exterior surfaces. Trigger spray.
'08 // Flint Mica // tC
[#] Jul 28, 2008 07:49pm
Kurisutaira
Reg'd: Aug 04, 2007
i have the same exact stuff jorge. no scrubbing needed just spray and let it sit for about a minute and wipe it off
[#] Jul 28, 2008 07:52pm
rafs-tc
Reg'd: Jun 06, 2008
Detailer
I used Rain-X bug and tar..... They came right off when washing... I considered the Turtle Wax product but the Rain-X did the job and it was a little cheaper.
[#] Jul 28, 2008 08:23pm
Reg'd: Jan 03, 2007
my bugs have etched into the hood paint, anyway to get rid of it? i tried claying, waxing, polishing, mr clean magic eraser, scratchX, bug/tar remover... but all is a no go :/
Pages: 1 2 >>
TOP: Home > Visual / Audio Mods > Detailing > removing bugs from hood/bumper
