| taking it to the track |
| camber off? |
| Request: Taking License PLate Bulbs Off |
| request: take off stock antenna |
| New tC owner, what do u think? |
sheepboy1130
ok..so i had that shilf knob problem...a gap between the obx shift knob and the thing..and i went to the dealer today..and they tired to fix it and they did really bad job.... they moved that thing on the shilft knob handle up so it looks like there is no gap between...but then..i cant fit any shift knobs..even stock ones... then i think they opend the boot but didnt close it fully..its like.. its jsut gay.........so im ging to try to fix it..but first.. i don no how to open up the thing so i can lower the thign on the shilft knob handle. ...hwo dou take it off can someone tell me how to lower the thing on the shift knob handle....??????? they highered it too much.. i just need to lower the thing on the shilft knob handle so i can fit any shift knobs..how do u lower it? |
There's a similar thread that might help you out. http://www.clubsciontc.co...d=14929&page=1#191188 ![]() CLICK TO DONATE & HELP MAKE THIS WONDERFUL SITE OF OURS BETTER! |
07blackedouttc
personally i would just get a different knob the knob looks like it is too short, your other option is get a aftermarket boot, you can find them all over the place NEED INTERIOR PAINTED? BADGELESS GARNISH? PM ME FOR INFO WANTED: HEADLIGHT LENSE OR CHEAP HEADLIGHTS FIRST CSM WITH NIA KIT |
You can put a small spring around the shaft under the collar of the boot that will allow for some fluctuation in height but also keep the boot tight up against your shift knob. If you're asking how to remove the housing around the shifter, just pull it. The entire interior of our cars is just help together with pressure clips. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
Remove the shift housing? TRD made a great DIY on this: http://www.trdsparks.com/install/00602-30301-140inst.pdf After you do that you can adjust the hieight of the boot so it meets your shift nob. -- edited thread title for specificity 11/07/07 11:34am EST ![]() "gonna wash my car before i take a nap.. can't rest well knowing i've got the entire cast of A Bug's Life on my bumper" - Vicious -- Want to post a "For Sale" thread? Check out the rules first. |
Mugetsu
^^like mayo posted OR you could just... unscrew the knob. run your hands down the two silver runners of the trim. around were your cig lighter is you will see a line ![]() grasp both runners and pull up slowly but surely(just enough to pop the clips out) now run your hands down to were the silver runners end. pull "back and up"(on the runners) slowly but surely just enough to pop them loose. now lift the whole thing up "CAREFULLY" or you are going to scratch the crap out of your center console. and do what you gotta do... (Hmm...sounds kinda like pulling a girls pants off...) wow that was more intense than that one time I forgot how to sit down... |
sheepboy1130
haha thanks..i finllay fixed it!! stupid dealers.. |
