Home > Visual / Audio Mods > Interior Styling > interior led help
interior led help
uuuuuhhhho
is it possible to have leds were your foot is to light up when you open and close your door?
any1 help?
[#] Nov 04, 2007 09:35pm
N8thegreat22
Brecksville
Ohio, US
When you open and close the door? That I am not sure about. It is possible to put lights in the footwells, I just dont know how you would do it when you open and close the door. I am guessing there is a way but someone else would have to tell you how to do that. Now if you just want to put them in the foot wells with an on/off switch, check out the 12" and 4" kits on Oznium.com. Thats what I have and they look great! Check out my gallery.
[#] Nov 04, 2007 09:48pm
  • $upervillain
One way to do it would be to tap the wiring into the dome light assembly because it already does that. Running wires across the headliner and down the a pillar would probably do the trick. I'm just not sure which wire you'd tap...
[#] Nov 04, 2007 10:19pm
uuuuuhhhho
ya i was thinking about that
but like the dome light is like a lil circuit board thing but i havn't taken it out all the way
idk i wonder
[#] Nov 04, 2007 10:51pm
CaptainJack
Buffalo Grove
Illinois, US
Do you mean like this?
Here ya go. Piece of cake to hook up! I'm sure you could connect it to the door wiring.
Glowshift LED Kit
the devious monkey photography
TEAM ECHO CHICAGO
[#] Nov 04, 2007 11:10pm
Massachusetts, US
  • The Techie
you can tap the dome light.. but you don't necessarily have to run a wire from your dome light all the way down.
the instrument panel j/b behind that plastic panel under the switch panel... yeah.. that thing.... has a place you can tap a ground that's triggered for the dome light... the same wire that the dome light uses for the 'DOOR' mode... (turns on with the doors...)
Decelerate your life.
[#] Nov 05, 2007 12:53am
TOP: Home > Visual / Audio Mods > Interior Styling > interior led help
