| Dome lights/fuse (LED question) |
| may of blown a strut, or have another big problem |
| Amp Kit Fuse Housing |
| Cupholder light fuse? |
N8thegreat22
Ok so as everyone may know I just swapped out all of my dome/map lights with blue LED's. Well my brother came home from college and I was showing him the car. Well I took out the backseat bulb to show him how it worked, and when putting it back in there was a sudden flash up in the dome piece. I got the bulb back in, but now none of the dome lights, or sunroof controls work. I am guessing I blew a fuse, but I dont know how to fix it! Now I am sure its an easy little thing, but some help would surly help! Thanks |
07TouringCoupe
If you think you blown a fuse did you check your fuse box. Since you say map lights im gonna say the fuse box under the driver side. You should never install a light while the power source is on. But check that. A car is only as good as it's driver. |
Beck
yeah its likely you blew the fuse. Check out your owners manual or perhaps the cover to your fuse box (not sure on the tC). One of those should show you what fuses are for what and where teh spare fuses are located. Just replace the one you blew with the same style fuse. Im guessing you blew the 'sunroof' fuse that most likely is interconnected with the dome lighting. ![]() Car Domain |
N8thegreat22
Ok everyone I figured it out!! Very easy, just took some looking around in the differnt fuse boxes. Thanks for everyones help! |
no... there's a fuse called "DOME" which is located in the engine bay compartment fuse box. 7.5 A LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
