tCFM08
is anybody using an Optima battery, if so are there any benefits to switching over to one of these. i also am about to put in a new sound system into my 08 tC, is this something that will benefit my system, and at the same time give me better overall starting power to my car.. thank you ![]() ![]() |
Higher cold crank usually and the fact that it's a "dry cell" battery means that it doesn't have acid sloshing around giving you unlimited mounting locations. I may be wrong but I believe they are a LITTLE bit lighter than stock acid core batteries too. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Rabid_Lemming
Not to thread jack, but what about those tiny little race batteries (ZPI used to sell them)? Any 411 on those? My car isn't the fastest car out there, but I'll tell ya.... Sometimes I haul more ass than a pimp driving a caddy full of hoes. Me to Pathik at PRacing.com about modding cars "It's like crack, but you don't lose as much weight...also you don't blow people for performance parts. So I guess it's nothing like crack" |
Mugetsu
I got one, its the odyssey 680 its tiny, i have yet to install it because its part of a bigger plan lol. but beyond space issues its pointless to switch to one, you can't have amps/subs hell you can't even run the stock head unit unless the car is running. wow that was more intense than that one time I forgot how to sit down... |
tCFM08
WOW i didn't know that, cool thanks for the info..so i take it this battery would not be recomended as a replacement of the original battery, but more as an additional add on, like in your bigger master plan..lol ![]() ![]() |
He's talking about the tiny race battery, not the Optima. Or at least I hope he is. The Optima batteries hold their charge better than acid core batteries. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
tCFM08
oops my bad for misreading it, so then the optima battery is an ideal battery not just for the function of the car, but also in the use of my audio system wiring set up ![]() ![]() |
Yes ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
SqMK
Optima batteries are certainly more light weight, and hold way better than stock does. If you are looking for performance, go with the redtop optimas (75/35 if you plan on staying with stock size); they weigh less and cheaper. If you plan on getting some big subs and other things with less emphasis on performance, go with the yellow tops; they pack more power but weigh more than the red tops and cost a little more. I plan on buying a yellow top optima battery, new tie down and possibly top-mount terminal clamps before the end of the month, mostly to spicen up that corner of the engine bay. That and I'll lose 10 lbs from stock by switching to an optima, which I won't complain about. Hello guys I am new here and am looking for friends |
tCFM08
Thanks, and sounds like an awesome set up you got planned ![]() ![]() |
tCFM08
i have decided to go with the Optima YellowTop Deep Cycle Battery - ULT-9040-218 what ya think, here's the specifics about it: http://store.summitracing...;N=700+0&autoview=sku ![]() ![]() |
08Crimson
Im sorry to also jack your thread but I have a few question pertaining to the subject at hand. Can someone tell me what the spec of our stock battery are; cranking amps, amp hour rating and weight? Thanks. |
SqMK
I meant to say I plan on getting a red top, not a yellow top. Hello guys I am new here and am looking for friends |
Stock cranking amps are probobly around 600-650 at most but not 100% sure. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
tCFM08
Well i am sticking to my yellowtop since, i will be adding so many audio system electrical components ![]() ![]() |
Mugetsu
Yes i izz, the Odyssey batts are race batteries plain and simple... ttp://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_135010_-1 whats up with the links not working ^^^ wow that was more intense than that one time I forgot how to sit down... |
tCFM08
you left out the h in http: all fixed now ![]() ![]() |
07blackedouttc
i had a red top and it was great never had a problem with it NEED INTERIOR PAINTED? BADGELESS GARNISH? PM ME FOR INFO WANTED: HEADLIGHT LENSE OR CHEAP HEADLIGHTS FIRST CSM WITH NIA KIT |
JHill
good choice!!! |
VIP_tC08
Here's my Optima yellow top, that i just recently instaled, along with tsunami terminals..![]() ![]() '08 // Flint Mica // tC |
nick06tc
I have a red top. Wanted a yellow, but I got a hook up on this battery, so beggers cant be choosers. I am pushing alot of power out of my 3 amps, and had bad dimming before. No issues with dimming now. About to do the big 3 upgrade to help even more. |
2tonetc
i have the yellow top...will get pictures soon |
