Home > Performance Mods > Nitrous Oxide > Free Nitrous
Free Nitrous
Pages: 1 2 >>
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
So yesturday at work we got a 02 civic hb si with nx dry nitrous system. this car was a trade in and the dealership didnt want it in the car and i was the lucky one to get it. Should i put this in the tc? I have every thing i need and the kit works fine.
[#] Oct 17, 2007 08:17am
Reg'd: Oct 21, 2005
$upervillain
You can put it on, but I wouldn't go any higher then a fifty shot. Not a fan of dry systems.
[#] Oct 17, 2007 08:22am
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
i dont even know anything of the bottle, all i know is its huge
[#] Oct 17, 2007 08:29am
doock87
Reg'd: May 18, 2005
Oil Changer
The bottle size doesn't determine horsepower shot.
You should definitely put it on the tc. 50hp is a good shot to use dry, as long as you place the fogger behind the MAF so it can pick up the nitrous reading.
The shot is determined by jet size. If you lost the jet or aren't sure the one in the kit is the size you need, look up jet size calculators on the internet and buy the correct size. Essentially, the most you'll be paying is ~5 dollars with shipping. You bought a nitrous kit for 5 dollars.
You don't know how lucky you are, honestly.
[#] Oct 17, 2007 08:54am
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
Theres two lines going into one nozzle that was in his intake. The bottle is almost empty and i've called two shops and both said they cant help me out. only thing i have leavet to take off is the purge that shoots the nitrous out of his hood. I might put on the kit today after i get the springs on
[#] Oct 17, 2007 09:02am
powerhouse21
Reg'd: Jun 10, 2007
Tech Advisor
Ive got the same kit on my tc. 50 Shot works great, you'll love it.
[#] Oct 17, 2007 09:20am
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
This wont damage my engine will it?
[#] Oct 17, 2007 09:22am
MrScion07
Reg'd: Sep 09, 2006
it could... but u should beable to run 50 shot all day... well till the bottles empty
[#] Oct 17, 2007 09:46am
doock87
Reg'd: May 18, 2005
Oil Changer
It won't hurt the engine. 50hp shot is a perfect size for a little extra "passing power."
You say it had two lines going into the nozzle? This would make it a wet kit by my understanding. Post a picture of the nozzle if you can.
[#] Oct 17, 2007 10:43am
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
yea has two lines into one nozzle, i'll take pics today of it
[#] Oct 17, 2007 10:49am
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
doesnt the wet kit go into the block of the engine are something, i thought dry was intake. how much do you think i can get for this kit if i sell it?
[#] Oct 17, 2007 10:50am
doock87
Reg'd: May 18, 2005
Oil Changer
Walp
Dry kits have a nozzle with one line going into them. That one line supplies the nitrous oxide. It's usually mounted before the MAF so the car's computer can compensate for fuel.
Wet kits have a nozzle with two lines. One of the lines goes to the nitrous tank, and the other splices into the fuel line. Wet kits deliver fuel and nitrous into the intake at the same time.
You might be thinking of direct port kits when you say "lines hooked up to the block." Those go into the runners of the intake manifold and are very complicated to install and remove.
Don't sell the kit! Nitrous is addictive and fun!
You could probably get in the neighborhood of $400 for it though.
[#] Oct 17, 2007 11:01am
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
I have no clue on how big the bottle is, its a decent size, whats the price to fill a bottle?
[#] Oct 17, 2007 11:03am
Reg'd: Mar 05, 2006
usually about 20-30 bucks depending on your area
[#] Oct 17, 2007 11:06am
powerhouse21
Reg'd: Jun 10, 2007
Tech Advisor
yeah like they said if it has 2 lines it has to be a wet kit. My dry kit has 1 line and thats just for the intake. Also its prob about a 10lb bottle which costs me about 40 to fill completely here in VA.
[#] Oct 17, 2007 11:45am
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
Well other then nitrous my engine is stock right now, would i break 15 sec on the 1/4 with just a 50 shot?
[#] Oct 17, 2007 11:47am
Mugetsu
Reg'd: Oct 11, 2006
You should definitely put it on the tc. 50hp is a good shot to use dry, as long as you place the foggerbehind the MAF so it can pick up the nitrous reading.
You mean in "front" of the MAF,(as in on the side the filter sits) a little mistake like that could blow some ones engine man...and dry systems use "nozzles" wet systems use foggers...
powerhouse21
Reg'd: Jun 10, 2007
Tech Advisor
thats my 10lb bottle mounted in the trunk.
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
My bottle is about that size
[#] Oct 17, 2007 11:49am
powerhouse21
Reg'd: Jun 10, 2007
Tech Advisor
yeah you can run the line underneath the spare tire through an open hole and right under the car and just zip tie it all the way.
[#] Oct 17, 2007 11:50am
powerhouse21
Reg'd: Jun 10, 2007
Tech Advisor
It always confused me when somebody said before and than somebody else said after. My nozzle is placed in the actual intake rubber tubing about 6 inches infront of throttle body.
[#] Oct 17, 2007 11:59am
doock87
Reg'd: May 18, 2005
Oil Changer
OK to clear up any confusion as to behind, in front, upstream, downstream, upside down and backwards:
DRY KITS: place the nozzle so that the nitrous shoots through the MAF.
WET KITS: place the "fogger" so it DOESN'T spray through the MAF.
And yea, by me it's 37.50 to fill a 10lb bottle.
[#] Oct 17, 2007 12:08pm
gicode0823
Reg'd: Jul 07, 2007
Tech Advisor
Do you need clutch with it ? if u buy 50 shots ?
because my friend broke his crutch with 75 shots ? or somethin ...
member of TEAM SCION EYED
[#] Oct 17, 2007 12:10pm
Mugetsu
Reg'd: Oct 11, 2006
and you meant MAF right not throttle body vvv cause you run a dry kit.
powerhouse21 wrote:
It always confused me when somebody said before and than somebody else said after. My nozzle is placed in the actual intake rubber tubing about 6 inches infront ofthrottle body.
[#] Oct 17, 2007 12:12pm
silver07tc
Reg'd: Oct 03, 2007
Tech Advisor
broke or did he just wear it out my riding the clutch.
Pages: 1 2 >>
TOP: Home > Performance Mods > Nitrous Oxide > Free Nitrous
